Table and Fingers
  • Table and Fingers
    What order and what steps do you go in to adjust a table and all the fingers? No specific problem. Just how do you go about checking to make sure everything is correct. Pics are always worth 1000 words.
    Re: Table and Fingers
    It is in the manual.
      undo all linkages and start with the one next to the 2 pin which is for the 7 pin then go in the back row and then 6 5 4 3 2 1
        First thing I do before any adjustments, is a "full and through" check of all hardware.
        The number of times I see mechanics try to get cell adjustments to work by just doing the adjustments is silly. I once stood and watched my old chief struggling. I'd already worked out that the tinaman nut on the main carb link was loose. Not enought to see it, but enought to have a good guess.
        No matter how many times he did the adjustments, it wouldn't pick the pins up. Or open the cells fully after a respot. He knew best :-))
          Cell set up.Drop table in spotting position to pindeck. remove all pins. remove all links, except 7 cell. Now ckeck freeness of roller under swanneck. if it moves freely good, if not shorten the small rod on the actuating arm.now ensure seven cell is open fully and adjst link. Then follow this order always working from back to front up each line of cells and ensure they are all about the same free play. 4,2,1,8,5,3,9,6,10. It is important that the cells are fully open to allow pins to spot through the cells and this is why it is best to adjust them here.Now raise table, close cells half way and check the pawl gap, maximum 1/8" and i mean maximum. Now close all cells fully and adjust the cell gaps by means of the small screw at the rear of each cell.use the wide end of the flat guage or if you do not have one,try to make all pins hang at the same height from the neck.Test machine respotting pins to ensure the cells close and open gently and thats it.If problems continue check the triangle spring hanger and bolt behind the respotting arm for excessive wear.
          Good Luck.
            I pretty much adjust my RSC’s the same as maister with a couple of exceptions.
            I prefer to adjust the pawl (aka batwing) first. Because if it is adjusted after the master link then that would change everything slightly.
            Also, When I disconnect the links (in spotting mode), I disconnect the #7 (master link) before adjusting the bell crank clearance. I’ve seen to many master links set to tight which would give a false clearance check for the bearing to bell crank.
            Triac
              ok triac, i agree , it works both ways. you call the pawl the batwing , in the uk it is called the chicken foot, but i think batwing is nearer.
              Nice one.Maister.
                Actually, I screwed up calling the pawl the batwing. I meant to say pawl gap to shifter cam (aka batwing). I never heard of the shifter cam link called the “batwing” until I read it here on this site. I believe that Kat (but not for sure) coined the term and it has stuck with me every since. When describing the pawl to one of my mechanics, I’ve always called it “the RSC actuating finger thingy with the corkscrew spring”.
                  <font size="2" face="Verdana, Helvetica, sans-serif">Yup, that'd be me. I've always used the term "batman cam" since it looks like the batman slihouette in the moon. Very flattering to know you guys are still using it. Thanks. [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
                    I always called them the fingerling (Pawl) and 'W' cam. works out good though with Pawl and W cam, as my last name begins with a W.
                      I thought the first thing was to remove and discard the stop bolt on the bell crank and then go on with the above procedure. I'm not saying this is correct but it is what Stahl's school taught.
                        I understand the 'purpose' of the bell crank stop bolt (as with the spring on the bell crank) but neither have ever "proven" necessary to me. I usualy remove the spring, the stop belt neither helps or hurts, so I leave it be.
                          Where can I get one of these magical manuals you speak of King?
                            <font size="2" face="Verdana, Helvetica, sans-serif">AMF has them for an arm and a leg.
                            Jeff
                              Otto -
                              I can bring by a copy for you, with some other useful tidbits too. When can I come? Always wanted to see your place.
                              Chad
