table problem
  • table problem
    hello all, i am having the worst nightmare with one of my machines, i have done all the adjustments on the table and i am still getiing oins dropping like flys in a stink cloud, can anyone please suggest what i should look for?
    just feeling my way out like a blind man at an orgy.
    Re: table problem
    J-man... is the table dropping them during spotting? On the way down? Are they dropping thru the shuttle? More info should help solve your problem quicker.
      Re: table problem
      Originally posted by J-man:
      ...dropping like flys in a stink cloud
      <font size="2" face="Verdana, Helvetica, sans-serif">I do like the description though. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
        Re: table problem
        Aside from machine positioning, table flagging and the normal adjustments, and assuming no broken cups, look for the following:
        -Sticky/dirty liners or pins
        -Worn tie link bushings
        -Yoke torsion springs: Broken? Adjusted properly?
        -Respot fingers opening all the way?
        -Cracked or broken yoke
        Awaiting more info in order to tune in to your problem.
          Re: table problem
          More information please but has this just started , if so check motor as gearbox could beallowing table to coast all the way down or electrical , possibly braking capactitor but we need more info. to try to help please.
          Maister
            Re: table problem
            - Table not level
            - Stabilizer rod end(s) loose or worn, allowing the table to rock front to back
            - Sticky table drive
            - Table drive loose on shaft
            RR
              Re: table problem
              Are the pins falling over on spotting as the pins make contact with the pin deck or as the table is on it`s return to zero?
              This would indicate either a not so level table or incorrect toe in.
              If you use AMF`s step by step procedure on setting up a table from scratch,you should be ok.
              The locating tool is a good guide to positioning the table on the pin deck.I don`t know whether or not you used this method of positioning the table?
                Re: table problem
                If all of your respots cells are open during spotting, and your shuttle isn't allowing double pins, and you say that you have done all of the adjustments, then maybe you set up the table with your half bubble toward the front of the machine instead of toward the rear.
                Just a guess. Please provide us with more detailed info.
                  Re: table problem
                  I had a problem similar to this a year or two ago... I pulled my hair out for a week on it. I'd adjust it, it'd run fine for 15+ cycles... I'd pronounce it cured. A day or so later, it's acting up again.
                  I was digging around the front end trying to figure out what was going on. I leaned on the spot/respot rods, and one of them made a 'click' sound. I found that the oilite sleeve in the cast pivot on the table had disintegrated... but you'd never be able to see it for just looking. It was just dumb luck that I leaned in the right place.
                  I figure what it was doing was moving normally sometimes, but if it tipped to the side a bit, it would bind up. After replacing the assembly, it ran like a champ ever since.
                    Re: table problem
                    Neat story GMan! I like finding things like that. All of these suggestions are great.
                      Re: table problem
                      if you are still having the problem and you have done everything else check you gear box on the table. i had a box that was going out. it had a few gear teeth broken causing the box to jerk causing the pins to fall over during spotting.
                        Re: table problem
                        We had a similar problem a couple of weeks ago what we found out was that the cup liners were all messed up and when we changed those the pins weren't dropping. Good luck in solving your problem.
                          Re: table problem
                          I was running into that problem
                          As I was digging around I rested on the spotting cups and noticed the x frame was broken.
                          Repaired and works great now
                            Re: table problem
                            Gman: great suggestion. Similarly, the shaft on which both the spot and respot levers (on the table)pivot can walk out one way or the other due to a loose or missing set screw. If it walks to the left, it will first affect the spotting.
                            Happened to me a couple of times.
                              Re: table problem
                              Don't overlook the microswitches,
                              we had a sticky one resulting in a shaking table.
