backend motor stater cleaning
  • backend motor stater cleaning
    Hello,
    Yesterday I started a new task. I decided to clean out my back end motor stators. What a job! How are you guys doing this? I used a can of electrical spray cleaner. Seemed to work OK but you need a lot to do the job. Do you guys put these in a parts washer or have a way to “soak” them? Just curious what others are doing.
    Thanks for the help
    Pat
    Re: backend motor stater cleaning
    Yikes! Why?
    Just give 'em a good blow-out with the hose once in a while. Anything more isn't necessary and maybe dangerous!
      yes a good external clean and check and oil check and if no obvious problems, no need to do anything till it fails.
      Maister
        At the previous center I worked at we would clean the coils with Zep cleaner, we had a 50 gallon barrel and by using a air nozzle with a siphon attachment were able to spray with a fair amount of pressure. Here with my limited shop and backend space I am making due with two different aerosol cans purchased at Grainger, one is a cleaner, less than $7 a can and the quick drying contact cleaner to protect the coils and magnets afterwards. I will say that I have found this combination, as well as, cleaning the rotor at the same time to severly quiet down any noise coming from the motor.
          Hey guys, if they haven't been done for years, the stators are mostlikely filled with dirt and grease from neglect.
          I would pull each one and clean it thoroughly on the bench. Electrical solvent, soft to medium nylon brush and a good blow with 40-60 lbs of air.
          Inspect, burnish the contacts on the terminal board, put back on.
          You will feel so much better that you did a complete job instead of just a shot of air. Your stators will run cooler too. I would pull my stators twice a year anyway just to inspect and lub the cent mech.
          Make sure that you log your work and soon you will get into a yearly maintenance rythum.
          Remember, our job is to protect, not neglect!
            I put mine in the solvent tank.
            It has not hurt them yet.
            They need a thorough washing to remove all the accumulated grease and durt.
              Right on Mike my problem was they were running hot. There is a lot of build up. What type of electrical solvent are you talking about? I have only seen the arisol spray cans. This works but there must be something better.
              Pat
                For a quick 'touch up' cleaning after servicing a motor heat, I hit it with ECG electrical parts cleaner/degreaser. Good stuff, cuts oil & grease, and carries the dust and black gunk right out of the motor, then dries away quickly w/ no residue. Doesn't hurt the winding lacquer or plastic parts... and it doesn't STINK... it actually smells fairly pleasant compared to some motor cleaners I've used that smell like a bag of organic fertilizer.
                    <font size="2" face="Verdana, Helvetica, sans-serif">Right on Jerry,
                    We do the same. Since my solvent dip is flamable we also dunk the winding in ZEP SPREE after cleaning in solvent tank. Spree is a water based cleaner that has ammonia in it. This removes any solvent residue and the ammonia makes the stator look like new, (also great for aluminum). In the summer we set the unit out in the hot sun a couple of hours to remove all the moisture. Winter we use a halogen lamp for drying. Have been doing this procedure for several years and haven't had a melt down yet.
                      I wish I could come up with the $$$ to pick up an ultrasonic cleaner big enough to submerge a stator and rotor... There's a non-ammoniated cleaner and a rinse solution I use for cleaning clock gearing that works great. I wish I could get a motor in that stuff... our motors would look like new all the time. Takes off oil, grease, dirt, etc... and dries off without any residue.
                      Problem is, a cleaner like that costs quite a few clams that I haven't got...
                        usually i only ever blow the stators out , but if there really nasty and won't clean up with the air, i take them home and put them in the dishwasher! if there really bad you might have to do them twice. then you put them in the oven at 425 for about 35-40 minutes! [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] they come out looking like brand new.
                          Originally posted by the old dirt man:
                          usually i only ever blow the stators out , but if there really nasty and won't clean up with the air, i take them home and put them in the dishwasher! if there really bad you might have to do them twice. then you put them in the oven at 425 for about 35-40 minutes! Turn lightly with a fork until crisp and golden brown. Dust lightly with onion powder and oregano and serve piping hot with a robust Italian herb and 30-weight gear oil marinara sauce...
                          <font size="2" face="Verdana, Helvetica, sans-serif">Garnish with a sprig of parsley, pour some some glasses of Chardonnay, and put out a tossed fresh field greens salad with raspberry vinagrette dressing... voi'la... dinner for four...
                          On next week's show, we'll show you how to make an easy, delicious dessert using backend motor gears and Lubriplate, topped with iron filings. See you then!
                          FIXED. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                            Originally posted by TheGMan143:
                            </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by the old dirt man:
                            </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"> Thanks G-Man [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] I think I just wet my pants [img]/content/btubb/images/%%GRAEMLIN_URL%%/shocked.gif[/img]
                              ok, ok. I guess you don't believe me! :p I have done 82/70 chassis in the dishwasher! [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
                              many years ago I did 5850 and 6525 chassis in the dishwasher! the 4400 wouldn't fit in my dishwasher so i used the garden hose on it! :p
                              just make sure everything is dry before you power things up and you won't have any problems.
