lane not spotting pins
  • lane not spotting pins
    I have a lane that, on ocassion, will drop the pins into the cups at the correct time, but the machine will not go into the spot cycle. it goes to pick up pins, closes the scissors and goes up as if it spotted the pins... any help?
    Re: lane not spotting pins
    Check the table drive unit for a bind or broken roll pin in the eccentric trip assy.
      Worn Table Drive Spring? Solenoied Spring Parallel? [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]
        sorry about being a total newbe... but... how would I check for the roll pins? do I need to take the assy apart? or what? it doesn't happen often enough that I've been back there and seen it happen.
          When You Get Tired Of It Happenig''It'll Get FIXED < BIG GRIN >
            First, I would operate the spotting solenoid manually a few times. If the roll pin is broken the table will not spot. If it does spot then check the rest of the spotting mechanism for a bind, such as the oilet bearings and the retaining collar. It doesn't take much of a bind to keep the solenoid from energizing. REASON. I'm in the process of rebuilding all my spot solenoids on my 90's which were neglected for a few years. About a week ago we installed a rebuilt unit on a machine. Two days later machine would not spot pins. We had failed to oil the bearings and after a few drops of 3in1 20wt oil, machine started to work fine.
                  I think I got it... I think it was just a lubrication problem... Thanks guys! first problem solved by ya'll!!! thanks!
                  Marc
                    check the link by the respot selenoid. could be broken. spot selenoid in the chassis might be goung bad. change that out.
                      check spotting latch this has happened to me before it may just be the little roll pin in there
                        ok... I thought I had it fixed but I was just running the machine and watching, and it did it again. the piece that goes into the notch in the eccentric, is in the notch and won't come out... any help?
                        Marc
                          this problem is getting worse. the latch is sticking in the eccentric a lot more often now. any help?
                          Marc
                            there are 2 roll pins in the TDA.
                            the little post runs through the TDA right behind the latch which is pulled up or left alone depending on which cycle its on.
                            on the part with the white nylon roller, look at the base and you'll see a hole where the roll pin goes. punch that out. slide the "ball joint thingy" part out. and use new roll pins. old TDA's have 3/32" roll pins. drill out and use 1/8" roll pins.
                            if its not that. the table is stoppingat zero, AFTER the white nylon roller goes under the flag.
                            or possibly the shuttle stop screw for the shuttle arm is out too far, or a lever has slid, which is causing a bind, which would explain why the shuttles operate, but not the pin cups or the TDA.
                            of course if you are captured during your missin, we will disavow any knowledge of your operation.
                              Worn LBS Rudder Cams
                              Back after 10 years with my mini lane
                              Hey guys! After building my lane 10 years ago I had to relocate for work and could not take my lane. It has been in storage ever since. I finally was able to bring it down...
                              The AMF dude
                              Transformer smokes
                              I hava a tarnsformer that started smokeing. I replaced the transformer and it runs a few seconds and starts to smoke again. Any Ideas?...
                              Turret 1-7-10 problem
