rack
  • rack
    when the table on lane 8 respots a first ball cycle the rack comes down and hits the top of the pins. is dosen't respot the set the table goes up as it does on an o-o-r!!!! need help in a hurry
    Re: rack
    i would guess same as otto's prob only opposite. either the TDA spring is missing from beneath the white nylon roller part. or you have a broken roll pin
      Re: rack
      thats usualy the roll pin in item 16 the pink roll pin there.if thats broke it will cause the table to slam down on top of the pins..and trigger the off spot switch
        Re: rack
        If you have a machine with two solenoids you might have a problem with the respot solenoid.
        To err is human but to really mess things up requires a college student.
          Re: rack
          Yup, the pink roll pin in item #15 usually shatters or snaps causing the latch to float on the eccentric disc allowing the table to long stroke when detecting pins. Look into this problem as you will soon be replacing a bent or broken yoke if you don't.
          That roll pin is a very common problem on 70s.
            Re: rack
            Dont forget the obvious ones. The carb link on your spot latch might be too short, halfass spotting and respotting at the same time. No return spring on your solenoid will do the same thing.
              Re: rack
              Carb = carbine ? Enlighten me!
              Dutch Fool
              So it goes.
                Re: rack
                Dutch Fool
                <font size="2" face="Verdana, Helvetica, sans-serif">carb = carbohydrate or carburetor, but I think the latter is implied. I could be wrong, since monkey likes his tacos loaded with carbs. :p
                Triac
                  Re: rack
                  Or carb as in 'carb'orator, a 'carb'orator link is a nick name for the ball style latch system which in older times was used to connect the throttle cable to the 'carb'orator.....or mybe I am mistaken.
                    Re: rack
                    Does the carburetor attach the the rack or the thing a ma bob?
                    Formerly known as Cyclone Lanes
                      Re: rack
                      Rack?? Still can't find one except on the pool table.
                        Re: rack
                        i like it when the seniors say "there's no rack on lane .." "did ya see who took it??"
                          Re: rack
                          <font size="2" face="Verdana, Helvetica, sans-serif">had one in Utah, 8 pointer the manager shot when he was young.
                            Re: rack
                            Now I had a very pretty lady in the other day. Now she had a NICE rack. [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
                              Re: rack
                              also check table position and yoke settings. if cups hit top of pins, does sweep clear the deck or do you have to return the sweep to zero as an off spot.if you have automatic sweep reverse is the deadwood left on the pindeck.
                              maister
