Need Numbers
  • Need Numbers
    Does Anybody have the part numbers for the belts and pulleys needed to slow down the rudder drive?
    i have several lanes that just throw the 6lb balls from one end of the pit to the other
    Why walk when you can ride!
    It aint over till the lights go out!
    Work smarter, not harder!
    Re: Need Numbers
    Do you have pbl`s or kicker wheels?
      Re: Need Numbers
      Call Ed Fox....888-435-6289,as poasted above will need to know what lifts you have...
      EBN Services
      Peanut
        Re: Need Numbers
        Silly me... I have the Mini PBL's [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
          Re: Need Numbers
          Here is the paddle drive and the 36 inch belt part #.
          000-027-710 V-Belt (36 inch)
          000-024-599 Adj. Rudder drive sheave
          I use the LBS stype black pulley which is bigger, so I need both belts to be 36 inches. I beleive the smaller one (for the small crank pulley) is either 33 1/2 or 34 1/2. It is in the book. I would suggest (as master said) to check in to the EBN pulley, I have not used one, yet, but the look to be vastly superrior to the AMF one.
            Re: Need Numbers
            i'll give Ed a call after the new year..thanks guys
