xli remote control
    Re: xli remote control
    It looks like just a plug-in remote display that you can use out the front of the machine to control it w/o running into the back... sweep run, table run, cycle, etc...
      Looks very handy. Think they will make one for the 82-30s? LOL.
      Gene Simmons for president!!!
        "Chassis continually monitors bin fill time".
        This is a very handy function. I think they've made a counter connected to the 9-bin switch. When it takes too long to fill the bin, the alarm system will be activated.
        Why do they not connect that system to the 'new style' sweep cam? When the sweep stays in guard position after interlock or gripper protect, the system will detect this kind of stops too.
          hmmm, i could see myself now in another center with one of those, cycling machines at will.
            this is the upgrade from xl machines. the box is hand held and carried to the machine to run it.you do not have a front end box on each machine 82/90 that is.there are other changes too , to motors and cams.i have not worked on them yet but believe this is the line.
            maister
              encoder style cam's no more adj needed,
                The motors have eproms in them and this controls the stopping and starting.I still prefer to be able to interchange motors and set cams to each machine for optimum stopping position.This is something that needs to be checked out in a years time to see how things have run.
                maister
                  Leakon: there is no GP.
                  Coors: Sorry, they're not wireless.
                  Raymond: The encoder still has to be adjusted for the home position.
                  Maister: If you like control over your sweep stopping points, You'll love this on the XL-i. You control the exact stopping position electronically from the control pad or the chassis. You can adjust the guard positions from the back without even going to the front of the machine! You only need to go to the front to adjust zero.
                  The hand held unit directly accesses the chassis for all info and control that the chassis has.
                  See the topic thread "What's the difference"
