Traditional wood or universal cushion..?
  • Traditional wood or universal cushion..?
    Hello members,
    I'm curious about the lifetime between the wooden and plastic cushions.
    Also like to hear your experiences with them, let me now…
    Re: Traditional wood or universal cushion..?
    SONICZZ
    I HAVE USED BOTH TYPES OF PLANKS. THE UNIVERSAL PLANK THE PROBLEMS THAT YOU WILL SEE IS.
    1. THE PLASTIC STRIP AT THE BOTTOM OF THE PLANK WILL BREAK OFF
    2. THE SCREWS THAT HOLD THE STRIP TO THE PLANK WILL BREAK OR COME OUT IF NOT LOC-TITE IS NOT USED
    3. I HAVE HAD THE PLANK BREAK IN HALF AT THE CENTER ALLOWING THE BALL TO ENTER THE PINWHEEL. (CAN BE A VERY EXPENSE PROBLEM WITH TODAYS BALLS AND THE PRICE OF THEM)
    4. I HAVE SEEN THE PLANKS BOW IN THE CENTER OF THEM HANGING THE LITE BALLS AT THE CUSHION.
    I HAVE WOOD IN ONE CENTER I SERVICE THAT ARE 20-25 YEARS OLD. THE PLASTIC PLANKS I USED DIDN'T LAST 10 YEARS.
      I like the plastic ones.
        I have found that the good old fashion maple, (I think they are maple) are the best. The wood laminated ones I have used and have not had one break YET. They are not guaranteed. I do not use stover nuts. I use grade 8 split locks and regular grade 8 nuts so they can be tightened when needed. I also completely agree with the above posting by PINHEADS.
          We use the Vantage Universal ones here with great results. No problems as described above.
          The wood planks are not made like they used to be and tend to delaminate or separate rather quickly. I ordered 2 from AMF a few years ago and they are already starting to separate (yes the assembly is put together correctly).
            Pinheads nailed this one. The other problem I had with urethane planks is that they would bow when hit by a ball and act like a slingshot and shoot the ball into the back of pindeck. That should only happen is shock is bad.
            Stick with original setup.
              Originals for us... We don't have problems with them, as a matter of fact off hand I can't remember the last time I pulled a cushion. Every house and person is different, see what works best for you, but for me original is the way to go
                I dont like any of em. Those one peice urethane jobs with the bolt holes i kept losing corners on. Then balls would idle on it. The original sandwich cushion is what i use the most, but they wear like a SOB and the wood splits. What we need are cushions made of titanium, covered in a sheet of flat pvc or urethane, like panels, but a wee bit softer. Cushion repair makes my brain bleed. Even worse is the hole that gets wallered out on the gearbox mounting bracket, where the pins for the shock mounts go. To hell with cushions in all forms. Im going to duct tape a giant throw-pillow on a cushion and see what happens.
                  Original wood all the way!
                  Formerly known as Cyclone Lanes
                    wood
                    SGT
                    U.S. Army/AVN
                    Retired
                      for the Universal, just cut a flew slits in the white strip which will cut down on the flexing and snapping.
                      perhaps it was coincidence, but the first few Universals i installed, the welds snapped, which made me think, the Universal/Plastic is flexing causing the weld arms to flex. and all the Universals are slightly Bowed in the middle from ball impacts. then i ended up having to use one of the Universals in an emergency, then i re-used another one. and they've been fine since.
                      Im still partial to Wood tho.
                        new amf ones are marine plywood so probably will not last as long as the maple ones.i am not keen on the plastic ones, i feel they flex when hit, putting pressure on the centre.
                        maister
                          Wood is GOOD.
                          We get 12 to 16 years from either type plank; however, the plastic ones give no warning before theyn break. With wood you either see the crack or start seeing splinters under the machine.
                            I still have some solid ash and red oak wood planks that I made in '82. Some of the chasers are younger than the planks.
                            Rep. Rob Bishop (R-UT)
                              I like the heavy-duty wood planks... we get a lot of years of service out of them. I did find that to keep them longer, hit them with ZAR or Thompson's when you rebuild them. It seems that when the plank dries out and gets splintery, it also starts getting brittle. Keeping a little oil in the grain keeps the wood moist and a bit more flexible... it reduces splintering and snapping quite a bit.
