I see many posts about distributor issues on this board. I was wondering, out of pure curiosity...In your opinion which is (was) the better distributor design...the 82/30 or the 82/70? I never worked on a 82/30, but the gear track over the table seems like it was a nifty idea.
Which distributor design?
Re: Which distributor design?
Only Benefit I can see that the 70's have over 30's is no distributor track to get hung on when teeth get worn or come off. But that doesn't mean the 70's don't have worse qualities than the 30's in certain areas, That is the only one I can think of at the moment.
Chappy
The distributors should use a pair of step motors for bin positioning, get rid of the reliance on trip cords, rods, clutch tension, etc. I will revamp the distributor as we know it, using said design, sell them, and retire before im 30. I m sure i can count on you all to buy at least one.The impossible often has a kind of integrity to it which the merely improbable lacks.
Originally posted by *70*PinMonkey:
The distributors should use a pair of step motors for bin positioning, get rid of the reliance on trip cords, rods, clutch tension, etc. I will revamp the distributor as we know it, using said design, sell them, and retire before im 30. I m sure i can count on you all to buy at least one.Even a old dog can bury a bone
There was some little German company at the trade shows that had a motor and optical sensor setup for distributor indexing, as I recall. It replaced the clutch, stop blades, etc. They also had their own gearboxes. Darned if I can remember what thier company was called.
ive heard many a veteren mechs swear the 30 dist is king. ive only pinchased on 30's while in college. but, i dont get the bad hype over the 70. especially with the "Bolw-Tech Endorsed" mods, 70 dists are awesome.
with the 30's your relyin on a little railroad track to guide the dist around. dist moves up and down with the table. now i dont knock the 30 dist as it is the 70 dists grandma ya know.
way i see it. once ya understand the ups, downs, left, rights, just alot less can go wrong on a 70 dist and/or related to the distributor.
Sounds like a great idea. I wonder why it never caught on?
'The more they overtake the plumbing, the easier it is to stop up the drain'. . . .would be my guess
Any questions??
the distributor is like a woman going into menopause it is very tempermental but if ya know how to handle it,it can purr like a cat..I like the turret on the brunswick A versions the best but is has its whistles and bells as well.Hell all these machines have whistles and bells if they didnt we wouldnt have a jobDEFINITION OF MANAGER IN THE 21ST CENTURY: (ADULT BABYSITTER)
You forgot one... the 82-70A distributor, which was a pretty unique animal. I heard it ran pretty good, though... Can't say for sure, because I've never seen one running.
I'm partial to the '70 only because I've worked on 'em a long time... The '30 design wasn't bad, except the idea of making the driving components out of stuff like cast aluminum and nylon was a bit of mistake.
I'd like to see some sort of a "SIMPLE" design change on the '70 distributor that would remove the clutch and linkage, which is the cause of a majority of the problems. Something along the lines of the magclutch like a Brunswick uses, instead of a mechanical stop blade and linkage.<span style="font-style: italic">Educatio est omnium efficacissima forma rebellionis</span>
It's called a D.I.D. DISTRIBUTOR INDEXING DEVICE. At first I was a critic but since I had one at the last center I worked, it worked flawlessly. No clutch, no stop blades, no need to parallel. It easily adapts to your existing dist. Alot of centers buy one to try and buy more after it has proven itself. They are not that expensive. Great Lakes Bowling Supply sells them. 1-888-653-2695Yeah but, We've always done it that way.
I've seen 30's but never worked on them. In my mind (and others) the distributor is the weak link of a 70. However on the same note a good tech that knows them and isn't afraid to tinker and sometimes baby them a bit can have a distributor on a 70 running great. The more you're around them and the more familiar you get with them the better you can get them running. You're gonna get pin piles, it's gonna happen, but if you know your stuff it shouldn't happen too often... Just my $0.02All I want in life is to turn wrenches and climb around pinsetters/pinspotters again :/
