Pro's & Con's of 82-90XL's
  • Pro's & Con's of 82-90XL's
    I Need some Feed back on the 82-90XL Machine.
    Re: Pro's & Con's of 82-90XL's
    there was posts on this in December, 2004.
    It is basically a 70 with a steel table, one chassis per pair and all the wiring in the boxbeam and on the table is removed. There is a front end control box, and table , sweep etc. can be controlled from front and back.The cells are set up differently and the yoke. New motors, 114" carpet drive belts instead of 112". new Motor support brackets and 70's can be upgraded to 70 XL which is really a 90XL but with an aluminum table.Frame is thinner and table is about 38 pounds heavier.
    maister
