More new pics
  • More new pics
    Got some new pics to share
    First pic is of a chassi with new bowltronics boards. You can also see the aux board has been removed. Also in the upper left is a bulb wired parallel to the 2nd ball light.
    More pics of the bowltronics contactors.
    A pic of the aux board removed. Looks much neater.
    The last two are of a vantage carpet which was originally white, hard to beleive! It tore about 6 in from the ball door so I drilled 6 holes and used shoe lace. Got through the whole weekend and I got it changed out on monday.
    Re: More new pics
    Great fix on the carpet.....you have come a long way Grasshopper [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
      Re: More new pics
      Great pics Grasshopper. are you sure they are Vantage carpets tho?
        Re: More new pics
        I can't see any of those pics. Anything I can do??
        Charley
          Re: More new pics
          Great pics! Can you explaine the chassis wiring. I like the wiring mods.
