8270 DOWN NEED HELP PLEASE
  • 8270 DOWN NEED HELP PLEASE
    I HAVE A 70 WITH MP CHASSIS STOP SW AND CIS SW
    I REPLACED SOME PINS IN THE C1 PLUG NOW I HAVE A DEAD PINSETTER AND BE FOR YOU ASK THE WIRES ARE RIGHT IN C1 LOL BUT I DO NOT HAVE 125 VOLTS IN CHASSIS NOR AT CB1 IN CONTROL BOX I THOUGHT THAT THE CIS SW OR STOP SW WENT BAD BUT I BY PASSED THEM NO LUCK NOT IN CHASSIS EATHER
    NOW HERES THE STRANGE THING WHEN I TAKE THE M REALY AND PUT A RUBBER BAND AROUND IT PINSETTER RUNS FINE BUT NEVER SHUTS OFF
    I KNOW ITS MOT MASK SW
    OR PM PLUG
    OR A&MC
    THERE IS NEVER ANY VOLTAGE AT CONTACTS
    ITS NOT CB1
    CAN ANY ONE THINK OF SOME THING ELECE TO CHECK
    THANKS
    DANIEL
    CHECKED THE C1 PLUG IVE TRACED 4 TIMES ITS RIGHT THERE IS 120 VOLTS COMEING IN AND WHEN I RIG THE M REALY IT RUNS BUT WITH OUT RIGGING THE REALY NO 120 VOLTS TO CHASSIS OR CB1 IN CONTROL BOX
    I CHECKED MASK PLUG BUT WHEN PINSETTER IS OFF THEREIS ALAWAYS 120 IN CHASSIS AND AT CB1 EVEN WITH OUT MASK PLUG
    FOR SOME REASON IT IS LIKE CB1 IS OFF BUT ITS NOT AND IVE CHANGED BRAKERS
    IVE BEEN ON THEASE THINGS 20 YEARS IT HAS ME STUPMED
    Re: 8270 DOWN NEED HELP PLEASE
    Check to see if you have output on the T4 transformer. Are they the "fuseable secondary" types? You might have a bad xfmr.
    Jon
      Mark
      This thing was running correct before you changed the pins ??
      You did nothing else but change the pins ??
      You did switch chassis with known working one ??
      When you changed the pins, Your sure you have a good contact. All the pins are set into the block like they should be ??
      Although they might be wired correct, Dont mean that the pin might not have a good contact with the wire.
      Are any of the pins on the chassis pushed back ??
      It's hard to trouble shoot from my puter so I'm just trying to get a clear picture.
        Hey, are you related to wepauls??? [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
          <font size="2" face="Verdana, Helvetica, sans-serif">I was wondering that too Jon. LOL
          Charley
            <font size="2" face="Verdana, Helvetica, sans-serif">[img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
              If your talking about me.......I'd take that as a complement.
              Is this a private joke ?
              I must of missed something!!
                Original post from Markrag is hard to follow. Not really an inside joke, there was a lengthy thread about wepauls spelling and grammar &amp; typing. That thread came to a good ending as I remember.
                Charley
