have you seen this before
  • have you seen this before
    ok guys new one for me. i get daring once in a while and when i have a bad gearbox i tear it apart and try to fix it. well i had an original backend gearbox, i belive it was national, snap the key way on the bronze gear on the u-bolt shaft that drives the distributor. i cant believe the distributor can snap that key way like that has anyone else ever seen this before. [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
    When in doubt check at bowl-tech
    When people are around no cursing and throwing things
    Re: have you seen this before
    yep had a few of them break in the 14 yrs ive been doing this job!!!
      how does this happen because the distributor shaft should have i just dont understand.
      could i have prevented it??
        Originally posted by mjs:
        I can't believe the distributor can snap that key way like that has anyone else ever seen this before. [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
        <font size="2" face="Verdana, Helvetica, sans-serif">I Can't Believe a table shaft could ever break. [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
        30 plus years and haven;t seen this on a Westinghouse.
        Run it out of oil and you and you loose the pin wheel gear.
        "How does this happen because the distributor shaft should have I just dont understand.
        Could I have prevented it?"
        I Assume A Pin Got Caught Between The Distributor and The Dist. U-Clamp...//Motor May Keep Running Before Over Heat(Thermal Protection) Kicks In.
        Kidney Adjustments And Pan Adjustments Might Be Desired....Or A Quicker Pin Chaser [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
          if you have the old big bodied motors and the distibutor drive is connected , not in the u housing , but straight to the distributor drive shaft, then yes any movement up or down and the shaft jams under the stator and it breaks off the shaft.I know two mechanics who have lost part of their fingers there.
          maister
