I got 1 question. I know its possible to put the arm on backwards/upside down. If the arm is put on wrong, which way will it affect the cups? Will they be too low in the horinzontal position or will they be too high?
Jerry, sounds like your speaking from experience. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] :p [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
Originally posted by Mike Stalker: Jerry, sounds like your speaking from experience. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] :p [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
<font size="2" face="Verdana, Helvetica, sans-serif">Well.....I actually fixed some other tech's slip up!.
<span style="font-weight: bold">There should be a triangle on one side of the arm. The triangle goes on the inside.</span> We did have one that was mis-triangled once....Viva AMF!
Another priceless gem in the archives of Bowltech !!!!
I can't thank you guys enough for this web site !!!!
There should be a triangle on one side of the arm. The triangle goes on the inside. We did have one that was mis-triangled once....<span style="color: #FF0000">Viva AMF</span>!
Originally posted by maister
you feel stupid once , <span style="text-decoration: underline"><span style="font-weight: bold">but only once and you do it only once.It won't spot.</span></span>maister
How about <span style="color: #FF0000">32</span> Factory 82-70 referbs with the XLI conversion !!
Oh they will spot ---- when every other adjustment is made to compensate....
Somebody tell me they are supposed to have the Triangles on the outside with the AMF converted 70-XLIs....
There has never been a set way of this item to be
machined. For years it has always been one way or
other as the item has no side differences. If this
item is removed from the shaft, simply look at
the direction of the mounting bolt before removing
and replace the arm as before. If you are unsure
of the correct way to install, simple remove the
cam follower from inside the arm. The arm should
be pointing in a straight down direction with the
cups laying level. The table will not set pins if
the arm is installed in the wrong direction.
I believe the part is cast iron....
Thanks though....the lane I am working on was big-time out of adjustment....
the table flagged perfectly ---- but to get the pins to spot on the spots, they had the top nuts of the spotting cups all the way tight and the bottom ones barely on....
Thanks a bunch !! Now I understand....
looks like the machinists over the years quit careing which side they punched the key way....
The yoke on the lane I am working on was so far out of adjustment had me wondering if something else was wrong....
had one that no matter which way round was just plain wrong, and when you put it next to another one the hole for the keyway just doesnt line up at all!!
