Sticks on 1st or 2nd ball
  • Sticks on 1st or 2nd ball
    I have an elco chassis with the omega tech board that will stick on 1st or 2nd ball. The problem is intermittent. I have changed boards and have moved the chassis to different machines and the problem follows the chassis. what inside the chassis can cause this?
    Needs more duct tape.
    Re: Sticks on 1st or 2nd ball
    Did you remove the small board on the side (above the mask & PM connectors)? Just cut the wires to the board, pitch the board & tape off the wires or cut them where they connect to the motherboard.
    Jon [img]/content/btubb/images/%%GRAEMLIN_URL%%/usflag.jpg[/img]
        on the omega-tek board, is it the type in which sweep and table start up at the same time? if so, these boards are really sensitive to the table/sweep cam settings.
          LMAO
          ummmm Jon
          Some of us mechanic's know what a memory board is !!!
            coors do you mean when the sweep is going from 270 to 360? That is when you have the problem.
                yes luster.
                the machine changes ball when the SA & TA-2 are open together. with the original (sweep return on TA1) boards, the window for the TA2 & SA to be open was splitting hairs. and if ya had a sticky/weak switch it would occasionally not switch, and get worse as the night went on. the '89 and later boards have the sweep return on TA2, which the TA2 & SA are open together for about a full second. never had a ball switch issue with those boards.
                  you can change the delay on the board yourself, or send back to Omegea and they will do it.
                    Right on the nut, Coors. We had similar problems with the old Lynch Omni Boards, which raised the sweep on TA1 also. Switched to OmegaTek after the change to TA2, never had a problem. Sold some of the boards to a little 10-laner with Elcos and had to fine tune all the switches.
                    To check which you have, run a second ball cycle with no 9 pin in the bin. After the sweep reaches second guard, pull out the TA1 and/or TA2 and see which raises the sweep and zero's the machine.
                      Coors sorry I read your note wrong. The guy asking the question might not have understood it. I goofed.
                        As I mentioned before I have swapped boards. I have used new and old boards from Omega Tech. I have also already removed the old memory board. I have also taken a board from a chassis that is working fine and put it in this chassis on the same lane and I get the same problem.
                          Darkhalf
                          There are 2 different Omega-tek boards. the one that causes the ball to jump is when the sweep is going from 270 to 360 the sweep beats the table to zero. That will make the ball jump. The other omega-tek board and newer style, the sweep will guard the table all the way up not allowing the ball stepper to jump. I'm sure you switch boards but are both bards the same style? Is the chassis staying on the same machine? If it is then check or change you TA2 switch or adjustments and also SA. good luck
                            i have also had this problem and found that if it's in the chassis check the following.
                            c-1 pins
                            table and sweep relays, theses can cause motors to coast.
                            change mk-70 pcb
                            if it's not in the chassis check timing and or replace sa ta-2 micro switches. most of my problems have been in the sa switch.
                            jim k.
                            jim k.
                              The chassis has been moved to different machines. The chassis has also been moved to machines that have had the TA2 and SA switches changed and the springs changed. If it is in this board why would the board work fine in a different chassis but put that board in this chassis and it will stick. For example lane #32 has a new omega-tek board, if I put that board in this chassis on lane #32 the machine will start sticking on 1st or 2nd ball. Lane #32 hase had the switches and springs changed.
