How's this for a yoke repair . . .
  • How's this for a yoke repair . . .
    this is the standard of repair i can do on an X-Yoke should anyone in the UK need one repairing
    the yoke is 0.020 off being perfectly flat after a weld with a Zero-3000 tigtronic.
    this was a fatigue crack i found that hadnt broken
    this was the main break that made me change the yoke
    the bearing fitted straight back into the recess with no fettling of the hole.
    Re: How's this for a yoke repair . . .
    hey good job kust becareful though i have done this before and fout it to be a new weak spot for the yole an idea would be to weld a sister piece in the recess to add a little more strngth
      Nice job.
        that was done with a welder that you can dial in the waveform you want and program it to the exact material grade and thickness, i have never had one fail yet (welder was in the region of $20,000 at current exchange UK-US rate)
          Very nice work indeed.
            Just a note my other trade is a certified welder. With aluminun the more heat you put into it the softer it becomes. Sure would like to borrow your welder it's a sweet machine. My exfather inlaw had a welding shop and I used a nice aluminum wire welder. It let you get in and out quicker than tig. But now all I got is an oxy act, and a old A/C welder. Oh by the way NICE JOB WELDING don't think you have any worries. Later chief
              Nice! [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
                Wow, you've got a lot to be proud of! Bet it will be there for many generations to use.
                  <font size="2" face="Verdana, Helvetica, sans-serif">So you're saying the equipment was the reason the weld is so nice, huh? I knew having expensive tools was more important than knowing how to use them... [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                  Just bustin' on ya, bud... hell of a nice job. My dad was an A welder (he built steam boilers for power plants), I learned it from him... I can appreciate the skill it takes to run a clean bead like that on aluminum. Great work!
                    Beautiful work Jez. Welding aluminum is very tricky so I leave it up to the pro’s. To bad you’re located so far or I’d send my work to you.
                    Triac
                      All I have to work with is a 30 year old 100 amp buzz box that's seen 4-5 different centers.
                      If I could have.... I would have stolen the huge Miller TIG machine out of the Hilton a few years ago. I fell in love with that thing so much I fried my chest many times from the radiation [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                      -- Larry
                        nice job dude!
                        you got idols you know [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                          Very good!!!
