I have a extra wire comming from the C1 plug. It's a black wire comming from H on the C1. It origanly went to the table contacts. Where is this suppose to go ?
Eletronic guru needed
I have 5 board chassis with Omega Tec 1 board. I'm putting in a bowl-tronics solid state contactor.
I have a extra wire comming from the C1 plug. It's a black wire comming from H on the C1. It origanly went to the table contacts. Where is this suppose to go ?Even a old dog can bury a boneTags: None
Re: Eletronic guru needed
Old School,
I haven’t installed one of those yet. Someone else might be able to chime in that’s done this. I would think you would go AB if this is what SS is being converted from.
If you can’t get help here, PM me for my e-mail. With all that’s going on, I don’t know if you would want to post both diagrams here, which is what I would need to see to determine the correct hookup.
Triac
It dont show any black wire going to the new table relay from the C1. Only thing it show's is a black junper wire comming from the sweep relay.And that needs to be run thru a breaker.Even a old dog can bury a bone
NEVER MIND
I got it. Just had to open my eye's. Works sweet. Weird not hearing any snap of the pointsEven a old dog can bury a bone
Yes old school they are very sweet. It is weird not hearing the clicking from the old AB contacts. Im sure too that you figured out C1-H goes to the circuit breaker and than the circuit breaker goes back to point 3 on the table contact.
Glad to hear you got it working.
Wang
I should known better then start a project after a long weekend. Womens city tournament of all things. My eye's & brain was not hitting on all cylinders.
It was the jump wire that confused me. On paper it made it sound like it had to be run thru the breaker.Even a old dog can bury a bone
Members
- Feb 2004
- 850
- 82/30,82/70,82/90,XL,XLI
- AMF and Qubica
- Various
- wood and synthetic
- 1953
well done old school mechanic i have not seen thes in the uk.thanks for the info.
maister
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
