scoring inacurate on amf 8270
  • scoring inacurate on amf 8270
    when a ball is thrown in the channel during the first cycle it is scored as a double miss therfor completing the frame on one ball. [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]
    Re: scoring inacurate on amf 8270
    assuming you have AMF scoring. sweep is drifting at zero. actualting the Start score microswitch located usually above the 10 pin sweep arm. need to adjust where the switch sits to give more forgiveness, or address the sweep drifting. this really happens alot if you have auto sweep reverse on a gutter
      <font size="2" face="Verdana, Helvetica, sans-serif">Yup. Exactly.
        I Think The Sweep Switch Must Be Intact And Making.
          WOW! Three Replies In 11 min. , You Should Have It Fixed Already.<Grin>
            Yes if you watch the sweep when it does its sweep reverse it returns to mechanical zero and then resets itself to electrical zero and will activate the sweep start switch twice , if not set low enough. sometimes it is necessary to adjust the sweep position at zero on the long rod to raise it high enough to help stop this occurring.
            maister
