Stripping out excess in SS chassis
  • Stripping out excess in SS chassis
    What can I clip and strip with an Omega Tek board?
    Re: Stripping out excess in SS chassis
    Table cable
      I belive that you can also take out the caps. in the chassis. there is also a small PC board mounted to the inside of the chassis, pull that off and the wires ( just clip them where they connect to the motherboard) the deep 30 it. I'm not even sure what it used to control.
        I have already removed the Aux. board.
          Hey TableHead
          How can you remove the table cable ???
          What about the finger protection micro switch??
          Also some of use still have old style scoring. So the only way the chassis knows what pins are left is thru the finger's by way of the table cable.
            I believe you need an Omega-Tek Expander Card for the MK-70 and correct scoring to remove the table wiring. This setup allows the chassis to take data from the scoring to make decisions instead of the table wiring.
            Matt
              we have all the table witring removed, we dont even run offspot swithces (twister pins offspot like buggery, and we got fed up of the machines stopping, we just train the FOH staff)
                Can I remove the tall caps in the chassis?
                  <font size="2" face="Verdana, Helvetica, sans-serif">Jerry; You Keep This Up And You Will Have An MP Chassis In No Time.......... [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                    I know.
                      I know.
                      <font size="2" face="Verdana, Helvetica, sans-serif">Then You No That Your SS's Are Aprox. 26 Plus Years Old [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
                        No Cap1 or Cap3 for me. i left Cap 2 there cuz i know thats where the expander board lug goes. was afraid i may have problems when i do get them. try one out for me, see if we really need them King
                          Thank you.
                            How about the pin light heat sink?
                              Worn LBS Rudder Cams
                              Back after 10 years with my mini lane
                              Hey guys! After building my lane 10 years ago I had to relocate for work and could not take my lane. It has been in storage ever since. I finally was able to bring it down...
                              The AMF dude
                              Transformer smokes
                              I hava a tarnsformer that started smokeing. I replaced the transformer and it runs a few seconds and starts to smoke again. Any Ideas?...
                              Turret 1-7-10 problem
