Part number(s) needed c90
  • Part number(s) needed c90
    Need the number(s) of these parts of our ballreturn. It is called ball director.
    Last time we ordered this part, they sent us a one piece part instead of the 3 we need.
    The 1 piece part doesn't fit between our rails because our ballreturn has a metal plate between those rails. The one piece part is much thicker.
    Does anyone know if these 3 parts have a special number and where we can order these parts.
    We already tried AMF europe, they still have found nothing.
    Re: Part number(s) needed c90
    the part number for the ball director is
    201 001 669. That is the olny number I have
      I also have C-90's. Curiously, they look nothing like that. How odd.
        These are the very first version of the c.90 ball return.not sure if i can get part number but suggest you call amf richmond and ask for a manual or if it is available on the web.sorry, i have not installed this version for at least 12 years.
        maister.
