MP Chassis
  • MP Chassis
    I have aquired an 82-70 MP Chassis that when connected up will not give any pindication, 1st ball light or machine run,program zero. Any clue as to what I need to be looking to get a machine to run? No matter what machine I put it on its the same problem?
    To The World You May Be One Person,but To One Person You Might Be The World.
    Re: MP Chassis
    Move All 3 Glass Relays To The Right(Last 1 Goes To The Farthest Left),,See What That Does..
    S Relay(Spot),M Relay(On-Off),and M2 Relay(Sweep Reverse Relay).
    M Relay Should Be The Offending Culprit [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
      Re: MP Chassis
      CHECK the pindication klixon.
        Re: MP Chassis
        Check continuity on the breakers, CB1 in particular.
          Re: MP Chassis
          Left To Right
          Program Zero SW.,CB1 3Amp,CB2 2Amp,CB3 2Amp.
          Bottom CB4 1Amp
            Re: MP Chassis
            Right on, Felix! [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
              Re: MP Chassis
                Re: MP Chassis
                Ignore what I said. I didn't program Zero. Sorry i read thing to quick
                  Re: MP Chassis
                  Ignore what I said. I didn't see program Zero. Sorry i read thing to quick
                    Re: MP Chassis
                    <font size="2" face="Verdana, Helvetica, sans-serif">Just Curious; You Didn't Read MP CHASSIS?
                      Re: MP Chassis
                      [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                        Re: MP Chassis
                        :p
                          Re: MP Chassis
                          [img]http://pic17.****************/VOL856/934456/1718790/23196461.jpg[/img]
                          Nice collection of relay's ay.
                          A bad connection of pc board in slot/connector, sometimes dirty or burned, can give you the problems you describe.
                          Does your deck light work on this chassis?
                          So it goes.
                            Re: MP Chassis
                            i didn't see program zero. What I read was pindication. I saw MP. At least I admitted it. Are you perfect?
                              Re: MP Chassis
                              Yes, Lampie my deck light works on this chassis. I can run sweep, table through the relays, can also run sweep and table from the switches on the side of the chassis. I get no pindication lights nor do I get first ball light. When I push the chassis program/zero switch nothing happens. Machine does not run.
