When replacing centrif mechanism on Westinghouse combo and backend motors, I use red super loctite to fasten mechanism to armature sets up overnight and turns rock solid.
Replacing Centrif. Mechanism
Re: Replacing Centrif. Mechanism
I agree with Alastair and King. I just replace the mechanism and switch with a SSSS.
Tom,
I think your going to regret using red loctite…that stuff is just about as permanent as you can get next to welding. Usually takes a lot of heat to get that stuff to break loose. If I were going to glue the mechanism down, I would use a milder loctite that is used as a bearing retainer.
JMHO
Triac
Too much trouble dealing with centrifugal switches and mechanisms. I replace any bad switches (boards) and mechs with Motor Start Relays (like Stahl's brand, also available from Grainger) on the combos and SSSS on the backends which I mount inside the rear control box.
I do this because no matter how well you keep up on maintenance, you will still have those few centrifugals crap out during league. Reliability is enhanced greatly using any of the above mentioned products."Where are we going, and why are we in a hand basket?"
Why even mess with C-Mechs, just as Kat said they'll just crap out. SSSS are great and trouble free. I like the lewis SSSS for my back-ends and Quality brand on the combos, but both work great where ever you put 'em.There is always more to life, but would someone tell me what it is!
Originally posted by 8270tom:
Thanks, will try your suggestions on SS replacements on my next repair. Didn't have to take mechanism apart after loctiting probably will be a bear to remove defective mechanism.<span style="font-style: italic">Educatio est omnium efficacissima forma rebellionis</span>
our owners will not stretch to solid state units, we have since found a source of incredibly simple cent mechs and with the use of the retro-fitted braking relay, the motors have become incredibly reliable. i only change maybe 2-3 cent mechs a year even with our heavy lineageWant your old pins collecting anywhere in the UK? email me on jezsmith@aol.com
