BOUNCE BOARD
  • BOUNCE BOARD
    JUST GOT ONE OF AMF'S LIGHT BROWN B-B HAVE NOT PUT IT IN YET DOES NOT LOOK VERY DURABLE.HAVE THE OLD ORIGINAL ONES BEEN IN OVER 18 YEARS. ONLY REPLACED 2 IN THAT TIME.HAVE HEARD VANTAGE IS PRETTY GOOD B-B??
    Re: BOUNCE BOARD
    We have bounce boards on sale. Go to <a href="http://www.murreyintl.com" target="_blank"><a href="http://www.murreyintl.com" target="_blank"><a href="http://www.murreyintl.com" target="_blank"><a href="http://www.murreyintl.com" target="_blank"><a href="http://www.murreyintl.com" target="_blank"><a href="http://www.murreyintl.com" target="_blank"><a href="http://www.murreyintl.com" target="_blank"><a href="http://www.murreyintl.com" target="_blank"><a href="http://www.murreyintl.com" target="_blank"><a href="http://www.murreyintl.com" target="_blank">http://www.murreyintl.com</a></a></a></a></a></a></a></a></a></a> and click on Specials.
    From there click on next (upper right)
    until you get to Specials for AMF. Alot
    of good product at great prices.
      Re: BOUNCE BOARD
      I haven't had any problems with the AMF boards. I've also got some of the Vantage boards that have been in for a while with no problems.
      Pete
        Re: BOUNCE BOARD
        We have a lot of the old dark brown boards in, they're good. We don't often have them go. And the new light brown/tanish phenolic boards from them seem to be holding up well also for us. Those white boards AMF came out with a good while ago on the other hand [img]/content/btubb/images/%%GRAEMLIN_URL%%/mad.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/mad.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/mad.gif[/img]
          Re: BOUNCE BOARD
          Use the U channel on the back with 5/16 bolts and double stover lock nuts.....they will never come apart.
            Re: BOUNCE BOARD
            Agreed.....here is a good mod, I will post specs later. Frosty is going though our pits now doing this.Using 1/4-20 bolts but grade 8 with stover nuts......
            Peanut
              Re: BOUNCE BOARD
              THANKS ALL APRESATE THE INPUT..
              SKY SKI..
                Re: BOUNCE BOARD
                Using the original style vibration dampeners is one of the best things you can do for a bounce plate. Those sure looked nice in the picture. With a place that clean and pretty I would be posting pictures every day. [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
                  Re: BOUNCE BOARD
                  Why not use the 5/16 'nut?
                    Re: BOUNCE BOARD
                    I'm sure you could king, and the stovers a must...
                    Peanut
                      Re: BOUNCE BOARD
                      Is the U-channel a new item or is it a "mod"?
                      -- Larry
                        Re: BOUNCE BOARD
                        You'll love it, 'Nut... our old mechanic did that with structural aluminum square tube he had cut in half... one of the bowlers he was friends worked at a metalshop, and had them fabricated for him. You wouldn't think it'd hold up, but they've been going strong. We never got around to doing them all... it was one of those "wish list" projects that never had time to happen.
                        2 'ribs' in each board have more strength than just the one, and U-channel is heavier than the OEM T-bars. We did about the same... G8 hardware, but with nice, fat washers to keep the nuts from wearing through the aluminum channel.
                        Surprisingly enough, we had better luck with a modified version of the "heavy duty" vibe dampeners. The OEM style (like those pictured) didn't last, but the "heavies" were so stiff they would bust the pit mountings. We found that by drilling a 1/2" hole through the middle of both dampener "legs", it had more "give" and didn't break pit brackets, but still held up 100%+ better than the OEMs did.
                        The OEM vibe dampeners are a very poor design... you can't bond rubber to flat steel vertically and the place 'shearing' force on it... it comes apart too easily. The design of the "heavy duty" dampener is the right idea...placing vibration on it as 'compression' instead of 'shear', but they're too heavy to soak up enough shock, so they pass it down to the brackets, causing breakage. I'd like to see the design of the heavy duty "pyramid" vibration dampeners, but with the stuff they use to make "red blaster" kickers out of instead of the heavy black rubber. I think that would be ideal... enough give to protect the brackets, but tons more durability than the OEMs.
                          Re: BOUNCE BOARD
                          <font size="2" face="Verdana, Helvetica, sans-serif">Im guessing it is a mod masternut it getting fabricated. if it is a new item, im interested
                            Re: BOUNCE BOARD
                            The U channel was available from AMF.....dunno know.
                              Re: BOUNCE BOARD
                              090 005 274 U Channel Support
