When you adjust the shuttle to 1-23/32" from the bin assembly sometimes both sides have different distances but the shuttle lines up perfectly with the bin.Do you just adjust the shortest side to the ST 6549 guage or center it?
Bin and Shuttle
Re: Bin and Shuttle
Re: Bin and Shuttle
my guage has always been. look at the back of the shuttle pin holders of the 2-3 pins. back of the shuttle pin holders should split where the pin base ring meets the surlyn of the pins already loaded.
all machines are different, im sure all pinholders are different, works for me
Re: Bin and Shuttle
Yes, adjust it to shuttle all ten and only ten pins.
Generally adjust the 7 pin side as this is the side that the shuttle drive operates. But you will find some shuttles look off set when you look down at the rear of the bin, but as long as it shuttles correctly, the gap is only a starting point to work from.
maister
