reset pin roller... no carpet flag tool.
  • reset pin roller... no carpet flag tool.
    I'm trying to reset my pin roller... I'm a newbee... I don't have the carpet flag tool, and I need to get this done... how can I reset the roller. HELP ME PLEASE!!!
    Marc
    Re: reset pin roller... no carpet flag tool.
    Pin Roller???? i am not sure what you are describing. Is it the carpet Belt?
    Peter
    Formally Sports Central
      the front roller for the carpet... it popped out of the brackets... I'm having a hard time rotating the brackets back to get the roller set in. I'm sorry I can't help much more than that.
      Marc
        Start the bracket back with a pair of channel locks. Then put a pair of vise grips on the top part of the “C”. Pull back with vise grips until you can pin it back.
        Triac
          Pry it back with a crow bar and put a quarter inch bolt in the little hole in front of the roller.
            <font size="2" face="Verdana, Helvetica, sans-serif">Please use channelocks......a prybar is dangerous.
              ok... I got the pins in... and now I can't get the roller bar back into the brackets... it seems like I can't pull it forward enough, any ideas?
              Marc
                Channelocks are a godsend if ya don't have the flag handy. Sometimes the front rollers are tight to get in, I usually just get the bearings near the hinges and pop it in to the cups with a big long screwdriver or something along those lines, just get in behind the roller and pry so it goes forward and pops in.
                  Drop the rear roller with the J hook, this will give you a little more room to work with.
                  It's up under the plow opposite the ball exit.
                  John
                  804-240-4982
                    Marc
                    <font size="2" face="Verdana, Helvetica, sans-serif">Make sure the carpet didn't get trapped under the guides at the rear... it makes it shorten up... also... reach under and make sure you don't have a pin stuck under the bounceplate... that causes excessive tension on the carpet, too.
                      I usually use a Cresent wrench to pull my front roller hinges back if a roller pops out never tried the channel locks.
                        I have always used a Shifting Spanner, about 12 inch, but you seem to have a different name for the spanners to us. Maybe adjustable spanner would be a more apt name.
                        I find the adjustable spanner much safer than the Flag.
                        Ottomatic use a big screwdriver to pop the roller in on the opposite side to the ball exit, with the help of your knees.
                        Frank.
                        always doing my best.
                          Oh, I must add, Ottomatic if your still trying to get that roller in, than you certainly are persistant.lol.
                          Frank.
                            Willey, I think anything is safer than those bloody flags!!!
                            I don't think my flag has been off the tool board in 10 years! Get them mole grips on it - I guess mole grips are called 'channel locks' in the US.
                            I'm Brian and so is my wife.......
                            http://www.badassbowling.com
                              I use two spring pullers on each side of the roller and lift, pull and drop it in the hatchets. This will save your fingers and a lot of good swear words for future use.
