Omega -Tek Boards
  • Omega -Tek Boards
    I have a machine that is burning up the sweep reverse relay. Changed chassis, gearbox/head, sweep run/reverse switch, checked capacitors, and checked for burnt/loose wires. Does anybody have other ideas. I apreciate the help guys.
    Re: Omega -Tek Boards
    This is a chassis with the MK-70 & expander?
      Yes it is
        DO YOU have a after market motor switch?
          The relay on the expander is getting fried?
            THE RELAY IS BURNING UP. IT HAPPENS WITH AN AFTER MARKET SWITCH AND A NORMAL SWITCH. I FORGOT TO MENTION THAT THEY ARE NATIONAL MOTORS. CALLED OMEGA-TEK AND THEY SAID IT IS A VOLTAGE PROBLEM IN THE SWEEP AREA. THEY CHASSIS HAS THE MK-70 AND EXPANDER.
              Is the motor wired right?
                I'm assuming that you have gone thru the C1. You might want to replace the C1 connector, possibly it has broken down internally and you are getting some arcing internally - I've seen that b-4! Just guessing at this point.... :p
                  I did find the wiring in the wireway to be set up for a SS start switch. Put wiring back to normal and a regular motor on the sweep. So far all is good. I will let you guys know how things turn out after about a year of run time.........lol. Thanks everyone !!!!
