masking unit lights
  • masking unit lights
    I have a chassis that has no masking unit lights.
    I moved chassis problem stayed with chassis. I moved omega tech boards and problem stayed with chassis. I changed c-1 pins no help. I moved fuses no help. any help???
    THANKS
    BAMM
    Re: masking unit lights
    Check for a busted common (ground) wire on your PM plug on the side of the chassis. If that checks out okay, check for continuity on the Pin Lamp Kilxon (OLL).
      EDITED...I read the post wrong thinking you were talking about the halo light.
      I'd start with Kats suggestion.
      Triac
        check that the plug/socket pins are in the correct place, especially the common, in the plug between mask and chassis
          Listen to the kitty....if it's an elco type chassis, look over the PM plug for broken or wireded out pins... :p
            well, that wasn't even close to selled right...I mean pins that are not tight...
              What kind of chassis?
              SGT
              U.S. Army/AVN
              Retired
                <font size="2" face="Verdana, Helvetica, sans-serif">Omega-Tek boards = Solid State Chassis (wanna-be MPs)
                  If this is a SS chassis and has no pin lites or 1st and 2nd ball lites I would look for a bad klixon or a loose piece of metal shorting out against the heatsink.
                    O.K. I changed the o/l part #070-005-666
                    and now it works. THANKS for the help!!
                    BAMM
