Table Shaft Measurement
  • Table Shaft Measurement
    What is the length of table shaft protruding from the self centering bearing case on the table drive end after replacing shaft to clear inside seal of gearbox?
    Re: Table Shaft Measurement
    I don't know exactly, for starters measure the machines next to it.
    I was doing a step by step slide show on how to replace the table shaft, that would be a good slide to include.
    JI
    John
    804-240-4982
      <font size="2" face="Verdana, Helvetica, sans-serif">It makes me feel inadequate.
        Seriously....after you get the spot and shuttle cams close in the keyway you cannot get it too far off so it would not run.
        Take the spotting solonoid assy. off the front to do the job and it will make it easier.
          Dont remove table motor when replacing shaft.
            <font size="2" face="Verdana, Helvetica, sans-serif">That just makes more work out of the project.
