1St ball AND strike cycle...?
  • 1St ball AND strike cycle...?
    We have a machine that will randomly, but frequently stick on 1st/2nd/strike cycles.... sometimes (most often) on strikes it will feel for pins, sweep deadwood away and mark strike, but first ball light stays on.... acts as though its waiting for pins.... press 1st ball stepper and cycle and it sweeps through and sets a full rack fine. Also sometimes this machine will STICK on one ball cycle.... as in.... Will set a new rack, and never switch over to first ball again, or will stay on first ball cycle even after respotting pins properly..... Also, once in a rare while this machine will show pindication while on first ball cycle....
    not sure if it was the previous frame's count or just random stuff???? Our chief mechanic and I are going crazy over this.... We've swapped out chassis, no burned/carboned pins.... We've checked sweep/table cams..... We've checked too many things to list.... has anybody seen this? Really need an answer asap!!!
    Re: 1St ball AND strike cycle...?
    You said that you checked cams, did you replace any micro-switches? With this kind of problem, I would replace the TA-2 & SA micros.
      What kind of chassis? I've seen this happen with S/S chassis & an XOP board.
        Clutch is right. Change out your microswitches for table and sweep and your problems will go away. We just had the same thing happen two weeks ago. Turned out it was a bad TA-2 microswitch. Changed it out and have had no problems with it sense.
        Wang
          You could try changing the chassis with another good working lane to narrow down the suspected problem area.
            That sounds a LOT like TA-3 and/or SC is acting up... those are some of the same symptoms you get when the machine dumps with 'sweep under table'.
            I would definitely change all 6 front-end micro switches to be sure... all it takes is a little oil or dirt/oil buildup to get into the contacts on them, and they can do some weird stuff.
              clutch has hit the nail on the head. good job Mr.Plate
                Whatever ya do, DON'T use Unimax brand switches! [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img] Use them Gen-U-Wine microswitch types! [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                  usualy TA 2 causes this problem causes this problem but I would as suggested I above I would replace all table cam micro switches and if problem persist change sweep switches....if this doesnt correct check the wire ways for a fallen screw or something conductive to cause grounding the terminals.I have had that happen as well...
                    I know it's pain, but changing one at a time will tell you which one casued the problem.
                      Very true... but I rarely have time to pull the switch packs apart up to 6 times to find out just what switch caused it... they're cheap enough that if I'm going to change one, even if I KNOW it's the one that's not working, I'll replace all 6 and completely eliminate the possibility that another 'old' switch is going to fail anytime soon.
                      Either way works... just a matter of preference and time.
                        If you have Omega-teks, they are quite sensitive to dodgy cam switches - especially SA and TA-2 (which in unison provide the ball/cycle change behaviour). It's not just because of the switch itself (being noisy/dirty), but because they are close together with respect to closing when the machine zeros (i.e when the table and sweep return to zero at the end of a cycle).
                        I'm certainly wouldn't disagree with the 10 or so posts before me, but I'm nevertheless curious what chassis/boards you have. In my own experience (and once again, I bow before the more experienced ppl that have posted before me), we have never had a cam switch problem whle using the Omega-teks. We certainly had a few problems after changing from 5 boards to OT, and had to replace some cam switches, but after that settling period, no probs since (and that was 7 years ago).
                        As Table Head said, I would definitely change the chassis before trying to attack the cam switches.
                        Andrew.
                          Is the GPS (gripper protection switch) on the machine,or has it been removed?
                            gps switch will not cause this problem this is a issue with the TA 2 switch or the circuitry!!!!
                              OK--I learned something new.
