removing aux pcb
  • removing aux pcb
    can someone please tell me the pros and cons of removing it and how
    Re: removing aux pcb
    Pros = It won't cause you any problems, Cons = you will loose the redundant ball memory circuit (no big deal). If you have Omega-Teks, you don't need it - cut it outta there.
      Oh yea, best to cut the wires where they go into the motherboard, remove the board & deep six it! [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
        Remove them, as wb8yjf says, at the motherboard.
        John
        804-240-4982
          As wb8yjf said, if you have Omega-Teks, then the Aux board serves no purpose.
          If you have 5-boards and you remove it, then you will lose the timer memory meaning the machine may not complete its cycle if stopped mid-cycle in particular positions, though this is rare since the machine has to be stopped in exactly the right spot. This timer memory causes problems when it fails (false cycling, interlocks). In other words, it's more harm than good.
          You won't lose the "ball memory" (1st/2nd ball)since that is in the 3-board.
          Regards,
          Andrew.
            we removed one to see what would happen and every cycle all we got was interlock. still running the 5 boards.
              Yea... some chassis need the Aux board with the 5-boards... others seem to run OK without it. We had a similar problem with ours. When we were first converting to Omega-Teks, we had a mixture of 5-board chassis and OT chassis. Certain machines could NOT have the 5-boards put back in if there was a problem... they just didn't play nice with the missing AUX-pcb. There was probably some minor wiring change done at AMF with the 82/70 chassis... who knows...
              Honestly, 8270kiwi.... if there's any way possible to talk the management into converting to Omegaboards, go for it... it will save you countless hours of troubleshooting/repair work, as well as reduce your chassis problems by like 1000%. It doesn't have to be done all at once...even if they just buy one board a month or every two months, it's well worth it.
              The cost of the boards is VERY low compared to the benefits they give you... I'd be comfortable saying that each board will pay for itself in a short amount of time just in labor hours for chassis/board repairs.
                Yea, Kiwi! GO FOR IT! You WON'T be disappointed!
                  In the 3 years I've been at my center, we have omegateks, out of 50 lanes I can only remember having a problem with 2 boards, 1-no strike cycle, 2-no 2nd ball light. Other than that they work so well it's like you don't even know they are there. I've worked at a center with the original 5-boards, troubleshooting those is an adventure I would not wish upon anyone! You should definitley get them. They will make you happier and make your bowlers happier.
                    You can replace the OmegaT. ball light triacs with ones from radio shack. They're labeled on the heat sink.
