yet again... humpies
  • yet again... humpies
    i work in a smaller house.. 20 lanes, and have humpys in all of my 10 lifts. i personally have NEVER had a problem with this particular system with the reduction pulley and rudder shock. BUT!!! with the lifelong light ball clutch, which i have installed 2 of them to try,i can see that the innovation is there, but far from perfected. i put the old style drive pully back on and it seems to work a little better, but over all the belt sheave for both units are too thin and when you get 2 heavy balls fight one another in the doors, the belt just slips... they need to manufacture it to use a wider-deeper belt for a sucessful upgrade. JMHO
    Re: yet again... humpies
    That and when a pin is blocking the ball and the inner hub comes around and drives out the pin, the total travel is reduced and sometimes can't push it all the way out. And if you increase total travel it hits the sides of the machines and bangs around from the hub turning. Good concept but I'd like to see some improvments.
    Charley
      agreed
        and I thought it was only me.
          Glad I only have one so far. It works , but it can be painful to watch at times.
            I have two lifts that the ball door belts keep slipin' off. I finally got sick of it and bent the pully to make it wider for the belt to run in. No problems yet. I just took a flat blade screwdriver and stuck it in the middle and bent it outwards.
              I'm working on somthing with retractible ball doors to eliminate the paddle all together. I'll keep you guys posted on how well it works.
                I made a mod to give extra spring tension. It's quite simple and works real sweet. Belts wont slip with this. I'll take my new digital camera & snap a couple photo's.
                  it is probably the same thing I did I drilled a hole in the connecting link on the tensioner and got the rod that goes to the new style tensioner and connected with a spring to the frame of the machine between the control boxes!! I had that problem on a pair of lanes did this and stopped that slipping problem
                    Lifelong has something you can buy for slipping also. Hopefully they will get the belt manufacturing issue fixed.
                    Charley
                      old school, what i do is place an "s" hook over the lift lower yoke shaft and open up the one end of one of the old springs from the long gong pbl's and hooking it to the belt tensioner. the only problem i have is belts tend to wear a bit prematurely. but i have one pair that no matter what, it wants to slip. i really think something is wrong with the device itself, but havent found it yet.
                        make sure ya backend motor isnt leaking oil on the belt and causing it to slip I had this problem one time with a pair of lanes!!!!!
                          Sorry it took so long. Server went down last night. KLH I'm sure there are 100's of mod's for this. Mine is a simple L shaped piece of steel.
                            You can see where the spring was rubbing against the shaft. When I had it hooked to the frame body. This is slipped between the tension spring & body.
                              neat little mod old school.
