Spot relay problem
  • Spot relay problem
    Tonight one of my machines went on a fritz. The spot solenoid would not engage all the way. It would buzz pull in about half way then fully engage. It was slow enough not to allow the spotting hook to latch.
    I tried changing the spot relay, that didn't help. Tried different working chassis, didn't help. Adjusted the table so it stopped at 355 degrees instead of 0, didn't help.
    I am thinking it's the solenoid. Is there a way to test these?
    This is on an 82/70 with SS chassis with omega teks. This particular machine had the dual solenoid setup but since then had the AMF single solenoid conversion.
    Thanks for any help.
    Mike
    Mike
    Re: Spot relay problem
    things to check... make sure shuttle stop bolt has not loosened and pulled out to the point that it is dragging on the stop block... check the whole spring mechanism (in my opinoin one of the worst designed deals with these machines) on the shuttle operator and make sure everything there is kosher. the solenoid is a mechanisim that rarely fails, not saying it cant. i would think that if the solenoid is pulling in, although slow, its working, but binding.
      I would agree with Bent wrench, sometime the bushine on the shaft right next to the stop block eggs out and can cause a problem too.
      A table that stops too late, past 355 degrees, will also cause this.
      John
      804-240-4982
        Mike
        <font size="2" face="Verdana, Helvetica, sans-serif">Make a test cord and hook the 120V directly to the solenoid, bypassing any pinsetter wiring. This will tell you if it is the solenoid or a mechanical bind after the solenoid.
        Check the following for mechanical binds:
        -None of the links are broken
        -Solenoid plunger is vertical, not out of alignment.
        If the solenoid acts up only when connected to pinsetter wiring, check the CB on the backend control box. This is infamous for casuing spot solenoid problems since it's wired into that circuit. [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
          check out the shuttle linkage
          I have had the bushings inside this go bad.
          there are brass bushings in there and if they crack they will bind up the linkage.
