Commonly used AMF parts
  • Commonly used AMF parts
    I posted this in another forum, I thought it may be of use to others.
    I can provide info on the most commonly used parts.
    I have my students fill out parts usage sheets for my classes, those are entered on an Excel speadsheet.
    The Excel file I have is an 18 class sampling of parts usage, you can filter the list a number of ways to get the info you want. It's a good starting point to build an inventory.
    I have also completed a merge to MS Word that will allow you to print labels with part numbers and descriptions.
    E-mail me at Jisbell@amf.com, I'll send the files to you.
    John
    John
    804-240-4982
    Re: Commonly used AMF parts
    I sent you an e-mail for a copy of that list. Sender is from cross-up@seacove.net Thanks, Paul
    SGT
    U.S. Army/AVN
    Retired
      I did too, sender is from need4speed69r1@aol.com. Thanks!
      Charley
        I'll send it next time I log on.
        John
        John
        804-240-4982
          could i have a list also bowlingmechanic72@msn.com
            Add me to that list
            wareclan@thewebunwired.com
              please send me the list also
              at spartalanes@sbcglobal.net
              thank-you gordy jr
              Life's a Garden... DIG IT !
