3 pin droppage
  • 3 pin droppage
    hey guys. Today i noticed on my lane that the 3 pin kept dropping on every complete respot. i think that the problem is the yoke? keeps dropping out of place?! correct me if im wrong.
    Re: 3 pin droppage
    check the finger cell,sounds like its bent and moving it.
    maister
      Re: 3 pin droppage
      i am sorry, i didnt supple enough detail. basically the machine is an AMF 82/45 and when it comes to respot a full table or pins, it does lay them but then as it releases the pins the 3 pin just drops, any sugestions.
        Re: 3 pin droppage
        <font size="2" face="Verdana, Helvetica, sans-serif">??????? 82/30 maybe?
        Charley
          Re: 3 pin droppage
          If its a 30, you might have a broken cup half. If its a 70 you probably have a tight cup.
            Re: 3 pin droppage
            Is the table touching the sweep rails? If so, adjust the diagonal rod.
            And put your "45 questions in the "30 section.
            So it goes.
              Re: 3 pin droppage
              clutch plate, thankyou so much. ordered new cups today
                Re: 3 pin droppage
                <font size="2" face="Verdana, Helvetica, sans-serif">My pleasure.
