c90 safety switch
  • c90 safety switch
    hi,this is just a small question,on our c90`s,we have a butterfly saftey switch,a lot of the kids who come into the centre tend to play with this switch,which cuts the power to the c90,the bowlers we tend to get in our centre are not too clever,and tend to bowl all the balls on the ball return rack,untill they have none left,before informing someone of the problem,which leaves me with a 10-15 ball underlane jam!.
    is it possible to wire the c90 safety switch to the chasis so that the machine cuts off when the safety switch is operated.
    iam using 82-90`s with 82-90`s 1st generation chasis.
    thanks
    Re: c90 safety switch
    This sounds intresting, I will ask out engineering staff to see if it is possible.
    That is easiy possible! Without a bunch of wiring changes.
    Could save a bunch of ball fishing!
    John
    John
    804-240-4982
      thanks,any help on this subject would come in good use.
        Yeah, i would be interested in doing this too. good idea mate.
        Ste.
        Ste.
          You could probably wire the swith in series with the masking switch. You could try it with a wire over the lane to check it real easy. All of the wire you would need if it will work is probably between the kick backs anyway.
            Fantastic Idea.
              Hi mate, im all up for wiring changes in centre being the spark, but you are forgetting one important thing.....
              (im a 30's man but i presume the ball still gets lifted high then comes down a chute on a 90)
              The ball is at top of the PBL return ramp as the customer opens the ball return, the switch turns off the back end chassis and hence the lane, but the ball has momentum and comes down the chute, all looks great for 5 seconds then a ball shoots out the C90 and WHACK......
              just a thought........
              If Wile E coyote has enough money to by all that Acme crap why doesnt he buy his dinner?
                Gadget,
                The problem with the C90 is when the switch is deactivated by a customer the front end stops, as you'd expect. When customers continue to bowl te balls actually jam in the C90. It would probably be imposible for a ball to be forced out by customers bowling when the c90 has been switched off. What Everton Fc is wants is someway to turn a pair of lanes off when the safety switch is activated. Even if the backend continues for 90 seconds, it will still limit the number of ball that reach the C90.
                  I don’t think I would run a switch in series or parallel to the mask switch since most c-90s have their own voltage source separate from the machine.
                  If I were to try and turn the machine off from the safety switch, I would use a relay powered thru the safety switch circuit and then use the contacts to break the mask circuit.
                  Another alternative would to install a very loud alarm to embarrass the heck out of them when the flip the lever.
                  Triac
                    it was just an idea,seems a bit too complicated really,think ill stick to the usual method,taking the capping up!,or limit the bowlers to one ball each!!
                      Its not that complicated really, as triac states, a relay off the safety switch that interupts the power to the chassis.
                      I dont know much about 70 or 90 chassis logic as i've had to deal with steppers and such, but i'm sure you have some sort of BLACKOUT switch on the machine???? I have 2 limit switches on the table that when activate connect a pin in the chassis to ground and blackout the lane.
                      You could run a single wire to this pin and connect it to one side of the C90 switch and connect the other side to ground. Lift the flap and voila instant lane off!!!!!!
                      Hmmmm i did know what he wanted, i have the same ball return, cant say that i get many underlanes from this happening though. I was just bringing up the old health and safety spiel.
                      kev
                        ANd how could i forget, well done Gerrard and Garcia!!!!! [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
                        Sorry mate, couldnt resist, been a lifelong fan of the reds, only just noticed your name, ooopps.
                        Hope you sort out your lane probs
                          well,...,yes,lets see at the end of the season!!!
                          iam going to have a go at wiring it up today,so ill let you know.
                          thanks
                            Gadget,
                            Maybe your FOH team are better at their jobs !
                            Actually there's no maybe about it they are. I just has a look at ours, nobody's can be worse !
                            So your a red are you ? Play the big whites next don't you. Were only just behind you chasing that elusive european place.
                              well,if you look at the league table,you both are behind the mighty blues!!!!
