I've been toying with this idea, did it on one machine for fun, and I am wondering if any of you out there have done this.
We all know that the C1 pins for the BE motor cook on a regular basis, some guys use gold pins others have a different fix.
I used a plug in type relay placed in the rear control box, we will call it BE2 and it had a 115 volt coil, I used the 115 volt output from the chassis BE relay to activate the relay coil of BE2, then ran a separate 115 volt feed to the contacts of the BE2 relay, then to the BE motor.
This took the high current away from the C1 plug as it only turning on a relay coil.
The BE2 relay contacts with much more substantial wire termination carry the higher current thereby saving the C1 plug.
I realize that I could have used a different coil voltage for the BE2 relay and did some wiring mods to accomodate that, my concern was swapping chassis, I did not one machine different from the rest for obvious reasons.
Your thoughts, has anyone else done this or something else?
John
