Kidny Mod
  • Kidny Mod
    I did't have any pinejector rods so I made a Bin srap work. You can use the same rubber mount that the pin ejector uses but you have to drill the hole to 5/16 in the bin strap. I have it on two machines and it works very well. I notice it helping the bottom first pins as much if not more than the head first ones. Well any way if you don't have any to spare you can use a bin strap.
    Re: Kidny Mod
    I used a respot cell finger,it works pretty good and allows you to have alot of adjustment.
      Re: Kidny Mod
      Isn't the pin ejector the part with the spring and the wood roller and the pin seating rod the part with the rod and rubber mount?
        Re: Kidny Mod
        <font size="2" face="Verdana, Helvetica, sans-serif">No....it is the part attached to the rubber mount on the catwalk.
          Re: Kidny Mod
          </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TABLEJAM:
          <font size="2" face="Verdana, Helvetica, sans-serif">No....it is the part attached to the rubber mount on the catwalk. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You are both correct and incorrect. The manual describes the rod with the rubber mount as a Pin Seating Rod and the Pin Ejector is the spring wound assy with the roller.
          However the parts book describes both assys as a “Pin Ejector”.
          Go figure.
          Triac
            Re: Kidny Mod
            i have the same names here triac, pin seating rod on the rubber mount and pin ejector with the wooden bobbin and spring.
            *thaught of the day*
            im well over 6ft tall, airbags hit you in the chest and explosive seatbelt tensioners HURT!! - as discovered on sat morning at 11:40am!, bang goes a perfect insurance history *sigh*
