Lifelong
  • Lifelong
    How are the front rollers holding up??
    Re: Lifelong
    Great....just use a metal screw for the cam rather than the plastic one......the metal screw is not noisy.
      Re: Lifelong
      Good to hear. How long you been running it? I’m a little skeptical after all the commotion of the humpback belts. So I’m taking a wait and see attitude.
        Re: Lifelong
        I wonder if that company is still a life. I have ordered some parts last year Bowlexpo paid and still didn't get them. I have written several e-mails but never got an answer.
          Re: Lifelong
          Pinchezr, their normal email address is one of those annoying (for those of us outside the USA) ones that only accepts mail from inside the USA. Try emailing them at lifelong300@yahoo.com
          Ray [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img]
          Ray Jordan
          Cybernetic Solutions/tenpintec
          Australia
            Re: Lifelong
            quite happy with mine, still using the nylon screw and gotta love the duro rings!
              Re: Lifelong
              <font size="2" face="Verdana, Helvetica, sans-serif">REPLACE THE PLASTIC SCREW.
              It will break and the roller body will ride against the roller hinge and wear it prematurely.
                Re: Lifelong
                i'll do that, but first i'm curious to see how long the nylon one holds up just for the sake of curiosity
                  Re: Lifelong
                  o yeah, just thought of somethin king.. the nylon bolt also comes with a tiny black hex-shaped piece of plastic that is supposed to fit into the top of the nylon bolt. did you put that thingy in? i figured the purpose of that filler is to prevent bolt head breakage.
                    Re: Lifelong
                    <font size="2" face="Verdana, Helvetica, sans-serif">I did....REPLACE THE PLASTIC SCREW!
                      Re: Lifelong
                      cool, just wondering. thanks clutch!
                        Re: Lifelong
                        FYI
                        We are no longer including the nylon bolts for the cam action. Initial testing was very promising, and the fact that it operates a little quieter with the nylon was the reason behind the use in the first couple of runs. You can use a 3/8-16 X 1 or 3/4 socket head cap screw as a replacement or give me a call at 877-235-8300 and I can send you some.
                        Sean
                          Re: Lifelong
                          Yea but I've been wiating over three months for a replacement belt for my hunpbacks. Yes you are working on it but how can you pay your bills with no belts????????????????????????????????????????????? ?????????????????????????? I have always been on your side BUT your service sucks. just the facts journior. yea yea I'll get a call, so what. allm I want is a spare belt so I can start warrenty on the belts that are failing. JR it's about service and you have NONE!!! later chief
