Mreessr's PICS
  • Mreessr's PICS
    I'll let Mreesrr explain his pics.
    Wang
    Re: Mreessr's PICS
    1. Nice mod on the kidney.
    2. The camera allows you to eliminate table wiring with "B" scoring.
    3. WTF......the cushion weldment that will last 100 years.....GIDDY UP....I want one.
      Re: Mreessr's PICS
      Wang, Thanks for posting the pics for me.
      The pin turner mod on the kidney is made out of old scrap flat gutter and edge board material.
      The cushion hangar weldment is at least 10-15 years old and was wondering if anyone else has one of these and if they still make them ?
      The scanner/camera setup is used like that to avoid the hoop style camera over the scanner. Wwe thought that was awful to look at so this is what was used. The scanner is raised with a 2x4 and the camera is shaved off and closer than it was supposed to be. Tough to get adjusted at first but mounting on 3/4 plywood took out the vibration or any movement from the capping.
        Re: Mreessr's PICS
        To bad the cushion board will not last.
