GE. B.E teardowns
  • GE. B.E teardowns
    Learning as we go.
    How do you remove the armature/worm gear assy. from a GE BE gearbox? i found an old manual here, but its really no help as most of the pages are missing. i have a few BE gearboxes that are leaking from the armature shaft and need to be replaced.
    Why walk when you can ride!
    It aint over till the lights go out!
    Work smarter, not harder!
    Re: GE. B.E teardowns
    Westinghouse and G.E. are Similar
    Drain Oil
    Remove the six cap screws and pry off the offset cover from housing(carpet drive).
    Remove the entire offset shaft assy. out by pulling straight out on the shaft while lightly tapping against housing.
    Remove the four cap screws and pry wheel shaft cap(pinwheel drive) loose from housing and slide cap off the wheel shaft.
    Slide oil collector tray out of housing.
    Remove wheel shaft assembly from housing by pressing downward slightly on end of wheel shaft and pulling outward on the shaft.
    Remove the four cap screws and pry distributor cap loose from housing.
    Remove distributor shaft assembly by pulling straight on shaft while lightly tapping against housing.
    Remove offset pinion nut, offset pinoin gear, offset pinion key.(*wormshaft spacer and worm shaft ob bearing)
    Remove four cap screws and by gently tapping on adaptor it may be removed from housing.
    You should be able to gently drive the whole assembly out..(**wormshaft spacer and worm shaft ob bearing)should come out now.
      If you are talking about just the worm shaft you will need a hydrolic press.I found that it is easist to take it to a machine shop.
      SGT
      U.S. Army/AVN
      Retired
        I assumed, he needed to get at the seals.
          Whoe night ranger, dude I'll fax you the pages you need. BE motors are not that hard. bUT BE CARE FULL BEFOR YOU TEAR THEM APART. Sorry but be patant and you can rebuild them for the cost of seals. Email me at gyoder@comcast.net with your info or call me 505-268-4371 as for chief wait new desk person has no clue ask for gary Yoder
