Distributor's suck!!!
  • Distributor's suck!!!
    I have one lane that the distributor is consistantly dropping the 10 pin into the top part of the 6 pin spot. I need to know how to get the distributor all the way over to that spot. Every other pin is being dropped perfect, but it doesn't get over for the 10 pin...
    HELP ME!!!!!!
    Marc
    Re: Distributor's suck!!!
    Adjust safety link to center between headpin rails. Shim lateral drive arm if necessary. Shim front part of distributor support post (between post support & suicide bar) if necessary.
    Finally, inspect the lobe on the 10 area of outer indexing cam surface to see if it is at fault. If it is cracked and allowed to give under the force of the lateral drive arm, it will fall back towards the #6 bin pocket.
      everything seems to be lined up, but it is catching on something at the 10 pin side, and not getting all the way over. These machines are old and haven't been very well kept, so assume the worst.
      Marc
        HELP ME!!!!!!
        Marc
        <font size="2" face="Verdana, Helvetica, sans-serif">I can help you. How about Sunday 11 am? Personal message me with an answer and details on parking, entering the club, compensation, etc..
          Marc
          <font size="2" face="Verdana, Helvetica, sans-serif">Check to make sure cam follower bearing on lateral arm is not catching on one of the webbings of the indexing cam.
          Check to make sure that your turn pan is not too far back and hitting the pinwheel. A grinding noise and/or rub marks in the pinwheel are tell-tale signs of the turn pan hitting it.
            After you center the dist. on the #1 shute rails, you may need to move it towards the 7 or 10 bins after you watch it feed an empty bin assy. You're allowed to move it so it feeds the 7 and 10 equally. I'm guessing that you checked the clutch and added the shim to the safety link end fitting and did all the other good tips that you can find here on this site.
            Dist.'s can be fun. Have you switched dist.'s with another machine to eliminate a problem?
            Rep. Rob Bishop (R-UT)
              I would give the drive shift a checking or swap with another lane.
                A good swift kick never hurt a problem distributor.
                  I understand.
                  Be carefull.
                  Don't get hurt messing with them.
                  Use the search feature here.
                  These questions have been answered dozens of times before.
                    Here is a longshot, but I've seen it happen a few times, especially on those distributors where we've had to shim the lateral arm out to make tighter corners. Be certain that the zerk fitting on the rod end for the safety link isn't hitting the rear distributor casting.
                    Again, this is kinda out there, but it can happen.
                      So it goes.
                        <font size="2" face="Verdana, Helvetica, sans-serif">i guess i can be an amf mechanic after all. i got plenty of practice on gs machines
                        insert witty and amusing signature here!
                          This one is a little off the wall too, but I've seen it happen.
                          The corners of the head of the large bolt, that holds the lateral drive cam follower to the dist casting momentarily hangs on the snap ring that holds the bearing in the cam follower.
                          Remove the bolt, install one of the thin dist clutch washers on the bolt, reinstall the bolt, the washer spaces the head away from the snap ring.
                          John
                          804-240-4982
                            Originally posted by Lampie:
                            <font size="2" face="Verdana, Helvetica, sans-serif">LOL @ Lampie! Were you a school teacher in a former life? [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
