Table adjustment
  • Table adjustment
    I have a lane where the table tie rod (used for leveling table to pindeck) on the 7 pin side is bent. I adjusted the table and everything spots perfect. ? is should I take the rod off and straighten it? Or should I just leave it alone? I guess I am thinking, if it isnt broke, dont fix it! Let me know what you guys think.
    Wang
    Re: Table adjustment
    Just add it to your honey do list.
    "Never put off 'till tomorrow what can wait until the next day"
    To procrastinate is...I'll wait till tommorrow and only freshman procrasitnate that long. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img] :p
    GETTERDONE!
    And FIXED!
      if is not broke........ well you know lol
        The bent rod adds character
          Change it or straigten it, if the table front to rear tilt was in adjustment, its out now, the bent rod also puts stress on all tie rod end uniballs, this will also cause an amount of table flexing.
          John
          804-240-4982
            the problem is that when the table spots it pulls unevenly on one table support and twists it.i suggest straighten it and reset front to back.
            maister
              fix it now or it will cause more problems later.
              SGT
              U.S. Army/AVN
              Retired
                Put on a new one Grasshopper.
                  I agree with King. I have tried to straighten them, but they usually get bent again. They are fairly cheap, just replace it.
                  Mike
                  Mike
                    wang stevie bee bee will fix it!!!
