AMF Simplified Clutch
  • AMF Simplified Clutch
    Pulled another one off of 21 last night. Seem to be a few failing in the same fashion over this last season. Could be age, could be design flaw.
    How many of you use this clutch?
    Are you also finding that over time the clutch plate ( steel washer with square hole next to friction disc ) begins to eat into the shaft? Once this happens, you have zero tension maneuverability and have to replace the shaft. I keep thinking if the clutch plate was thicker and had more surface area it wouldnt act as a razor blade on the shaft. I made some homemade clutch plates out of the spacer/washers used in the cushions, took em down to the fab shop and punched the square holes in em, they are doing well, and i think its because they are thicker and cant bite into the steel as easily.
    Am i the only one having this problem?
    Re: AMF Simplified Clutch
    Look's like non of the mechanics like them. They all tried them and threw them out again. I think the most problems come from the driveshaft connecting the distibutor to the motor. I made a longer distributor shaft and added an extra motor. Since than my distributor failures are almost 0. The distributor is running a bit faster now inorder to distribute the pins faster than the pinwheel dilivers them. In my opinion this is the only way out! I'll try to make some photo's and post them.
      <font size="2" face="Verdana, Helvetica, sans-serif">draakollie.lotje@wxs.nl
      Martin
      So it goes.
        I have 17 I will sell.
        Used less than 2 months.
          <font size="2" face="Verdana, Helvetica, sans-serif">Hmmm, interesting. I'm surprised they didn't go into one of King Enterprises dumpsters that you often highly talk about. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
            Originally posted by Kat:
            </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 82/70 king:
            <font size="2" face="Verdana, Helvetica, sans-serif">Hmmm, interesting. I'm surprised they didn't go into one of King Enterprises dumpsters that you often highly talk about. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">They are headed there soon.
              Hey Pin Monkey:
              Happened to stop by a friend of mines house today. He and I have been playing around with these clutches now for some time. His latest idea is somewhat similar to yours. He as well as I have had the plate cut into the shaft causing loss of preasure to the disk. He took a fender washer that would fit over the shaft and tack welded the washer that the pinion bushing flange rides against to it. Then he faces the fender washer flat and also polishes the surface that contacts the disk. Now you have a thicker surface on the shaft so it will not dig in, and also it can slide on the shaft better. As soon as I can I'll try and get a picture or two up.
              AMF DOCTOR
              The doctor makes house calls.
              AMF DOCTOR
                awesome, sounds good doctor, look forward to seeing you guys' work.
