Rear roller support bracket snapped
  • Rear roller support bracket snapped
    Had one of the rear roller support brackets snap today. Fitted a new one in just under 90 minutes.
    The key today was having a really good metal drill bit ready. This is only the second one I have done in 12 years in our bowl.
    Mark
    Re: Rear roller support bracket snapped
    the one ON the kickback? Not the question mark one? Yeah, those suck, we drill em out and bolt em up nice with grade 8 hardware. Good job.
      Rear roller brsckets are the bane of every mechanic, especially during league time. An retired mechanic i know designed a mechanics bandaid for rear roller support failure.it works like a charm and for $40 bucks it is worth it. it allows you to get you up and running in one minute and allows continued linage till you have a chance to get a new support on. For more info.. yu know where to find me.
      "if it ain't broke.... let my b-mech work on it."
      Help me!!! My 70's have me by the nuts.
        Joeyamfi is in dire need of a 'B' not just a pinnie.
          joey pm me with details
            <font size="2" face="Verdana, Helvetica, sans-serif">I think replacing the front roller support hinge would be harder to replace.
              We had some prior idiot WELD a few of those on. DOH! Talk about a pain in butt. Had to grind them off!
              Valkyrie: The American made motorcycle that Harley Davidson WISHES it could build.
                <font size="2" face="Verdana, Helvetica, sans-serif">They came from the factory like that on initial installs. Bolt-ons were a replacement kit. If it was a replacement that was welded on, it seems it would be more trouble than it's worth and risking not aligning the retainer up properly. I like using the old one that's sheared off as a drill template, then grind the SOB off and bolt to kickback with heads in exit area.
                  Yeah King ,I agree. Only ever done one. It snapped off in my hand !
                  I told tech I was on with" that is not a true reflection of the job"
