Marc
PBL paddle sticking
Member
- Aug 1999
- 2547
- A-2s, GS-X, 82/70-90
- Brunswick Vector Plus HD
- Brunswick Envoy
- Pro-Anvil
- 1985
Re: PBL paddle sticking
Define stuck. Is the rudder catching on the filler plate or is the LBS cam tripping, causing the rudder/paddle to snap out of the way? Disconnect the LBS drive rod from the crank plate and move the rudder as a whole unit with the LBS in the "sense" (not power-drive) mode and see if the rudder is catching on the filler plate. You may need to move the rudder arm back or shim the lower mounts for the LBS.
P.S. I'm sure 82/70 King will chime in here about tossing the LBS units into a King Enterprise dumpster or something. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
The LBS is actually a pretty decent unit and does work well when adjusted properly. It would work even better if I can find a winged paddle that held up long enough."Where are we going, and why are we in a hand basket?"
Member
- Aug 1999
- 2547
- Brunswick Envoy
- Pro-Anvil
- 1985
Increase tension on belt tensioner , make sure there's no oil on the belt causing slippage, and lastly, make sure the right belts are on.
Ball lift to tensioner should be 1400 and tensioner to rudder should be a 1380. Another thing would be to check to make sure there's adequate spring tension on the tensioner. Stock setup is the spring rod with spring. I've replaced all of mine with Brunswick long turret adjustable springs so I can dial-in the right amount of tension; enough to prevent atoppage of rudder, but not enought to put excess strain on oilites in tensioner."Where are we going, and why are we in a hand basket?"
Member
- Aug 1999
- 2547
- Brunswick Envoy
- Pro-Anvil
- 1985
The adjustable spring is a two piece thing.
There's the spring: 12-400051
and the spring hook: 12-402051
You can get it from any Brunswick parts supplier."Where are we going, and why are we in a hand basket?"
Make sure it's getting under the lift. Raise your ball Lift.If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
Originally posted by otto matic:
no no no... It only gets stuck when a ball comes in now... if the paddle is going in the direction the ball is coming from, it will not push the ball out and the weight of the ball will stop the paddles movement.
MarcIf at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
Tech of the Year 2009
- Nov 2000
- 19908
- AMF 82/70
- AMF Accuscore +
- Phoenix S & Walker
- Brunswick Pro Anvilane
- 1982
Tech of the Year 2004,2008
- Jun 1999
- 4204
- A- 2 / 8270
- Qubica / Frameworx
- Phonix-S / Kustodian
- Prolane / HPL / SPL
- 1983
Kat we use Brunswick springs part numbers
12-400806-002 spring
12-400806-003 hook
Are these the ones you are refering to. They have worked great for us.Peanut
Member
- Aug 1999
- 2547
- Brunswick Envoy
- Pro-Anvil
- 1985
Masternut:
I'll have to check with my books at the shop to see exactly what I have. I was going from memory (as bad as it is) on the numbers."Where are we going, and why are we in a hand basket?"
Member
- Aug 1999
- 2547
- Brunswick Envoy
- Pro-Anvil
- 1985
After researching some part numbers, I've found that Masternut's numbers are correct. I don't know where I pulled those others from. [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]
Anyways, here's a pic of our tensioner setup. It has the Brunswick adjustable long turret spring. Also, we did away with those pesky snap rings on the lower shaft and used lock collars butted up against flanged oilites to keep the casting from floating. We chose flanged oilites to keep the oilites from falling out like they occasionally do.
Red Wing Paddle
<a href="http://www.bowlingproducts.com/graphics/redwing.jpg" target="_blank"><a href="http://www.bowlingproducts.com/graphics/redwing.jpg" target="_blank"><a href="http://www.bowlingproducts.com/graphics/redwing.jpg" target="_blank"><a href="http://www.bowlingproducts.com/graphics/redwing.jpg" target="_blank"><a href="http://www.bowlingproducts.com/graphics/redwing.jpg" target="_blank"><a href="http://www.bowlingproducts.com/graphics/redwing.jpg" target="_blank"><a href="http://www.bowlingproducts.com/graphics/redwing.jpg" target="_blank"><a href="http://www.bowlingproducts.com/graphics/redwing.jpg" target="_blank"><a href="http://www.bowlingproducts.com/graphics/redwing.jpg" target="_blank">http://www.bowlingproducts.com/graphics/redwing.jpg</a></a></a></a></a></a></a></a></a>
By the way; I still haven't found the use for these [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
I would hesitate to use a red wing paddle unless they have finally made them sturdy enough not to break.The yellow wing paddle did not succeed and so far I have had to replace at least 4 out of 6 red wings maybe more I lost count.Well we're safe for now. Thank God we're in a Bowling Center.
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
