Paddle stuck
  • Paddle stuck
    In reference to post about paddle stuck KAT had to take a stab at 82-70! How come you won't reply to your own e-mails??????
    Rich
    Re: Paddle stuck
    <font size="2" face="Verdana, Helvetica, sans-serif">Which e-mails?
      Re: Paddle stuck
      I sent 2 private messages 10 days apart both showed they had been read by you! The first said nice pix's! and what is the spring on the left side for???
      Rich
        Re: Paddle stuck
        I replied to the first one the day after I receive it. Anyways, if it got lost [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] here is basically what it said.
        Thanks for the compliments on the pics. As far as that spring on the left, it is a temporary thing we do when the ball lift is changed, rear roller pulled, or BE gearbox changed. We use it as a sight to make sure the motor to carpet belt runs true and straight. I like my belts to run very true; the belts must run perfectly between this spring and the ratchet wheel. When I satisfied, this is the case, the spring is removed (usually 2 days later.) This helps me determine if any questionable pulleys that have a wobbling motion actually do cause a problem.
        Again, sorry if you did not get my PM reply, as I know I sent it...so I will have to see if somethings screwed up with my PC. Anyways, hope that explains it and thanx again for the compliments. [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
          Re: Paddle stuck
          I'm uncontrollably curious...
          What spring? Or, tell me what original post that was?
          Thanks,
          Andrew.
            Re: Paddle stuck
            THANKS!! I tend to get a little fi$$ed a little quick sometimes !!!!!!!!!!
            Rich
