Laminated cushion planks
  • Laminated cushion planks
    Is anyone else having problems with them splitting down the middle? I have replaced 6 in the last year. One only lasted a month. All my newer solid planks are holding up great.
    Who makes a solid plank? I know JCP and AMF no longer make them solid.
    Mike
    Mike
    Re: Laminated cushion planks
    What brand are the one's that are splitting?
    BAMM
      Stahls black planks are virtually indestructible. I have had no issues with the plank at all. Add a stahls cover with just the top 6 holes cut out and you have a great cushion to last.
      Wang
        So far it's just the JCP boards, I have only had the AMF ones for 2 months. But they look almost identical to the JCP boards. The AMF boards don't have that cheap metal support, or screws.
        I ordered the AMF ones thinking they were still solid, then to find out they were laminated.
        Mike
        Mike
          Mike
          <font size="2" face="Verdana, Helvetica, sans-serif">So far my laminated AMF planks look good. They have been in for about a year or so.
            I am testing laminated planks for an aftermarket mfg...........it is holding up well.....
            Some companies make certain items great....other item only so so.
              The 90's we just put in were laminated - like the kickbacks.
              Time will tell!!!!!!!
                AMF started with the laminated planks a couple of years ago. So far all that I have installed are still solid as a rock. Just keep good pads and rubber on them. That is what takes the real shock.
                  Good, at least people are having good luck with the AMF planks. Of the AMF ones I do have installed they still look new.
                  All my cushions have new rubber, rubber sponge, and the velcro cushion facings. So far the cushions facings are wearing good. Have one that's been in a year and a half and starting to show sings of slight wear.
                  Thanks for your input.
                  Mike
                  Mike
