Who loves those pivot post replacements for the front roller hatchets? I tell ya' the mechanic before me would not be alive if I had my choice. This things have gone 2 years without any grease or service to them. I'm doin' a fair amount of cutting, grinding and drilling if ya know what I mean. Boy when it's all said and done there is nothing better that a good rollin' roller!
Pivot post
Re: Pivot post
If you're talking about the Enviro bushings (lubelss fittings), they're fantastic. Every pit that is serviced, gets these. Clean the posts up real well, and slap 'em in. I'm also converting to the Enviro sweep "oilites" on the tops (under the catwalks)."Where are we going, and why are we in a hand basket?"
Re: Pivot post
If I had to replace one, I would replace the rear side plate nad do it off the machine.
Re: Pivot post
Originally posted by gw407:
Kat,can you post part #'s for the enviro and who you get them from? Thanks"Where are we going, and why are we in a hand basket?"
Re: Pivot post
I think he is talking about the replacement stud.
OK, I'll leave now."Where are we going, and why are we in a hand basket?"
Re: Pivot post
Peanut:
Very true. While the Enviro is a little more costly than the standard oilite, to me it is like insurance of not having to go through the added expense (parts & labor) of having to replace a shaft due to the hatchet seizing up. Spend the couple of extra bucks now and never have to worry about it again."Where are we going, and why are we in a hand basket?"
Re: Pivot post
I have posted this before. Get a $20 air powered die grinder from wall mart, menards, home depot, or wherever with an arbor for a 3" cut off disk. Cut the plug weld off and rock the post up and down with a vise grip. 20 minute job tops. Use Stahl's counter bored washer if you wish.Yeah but, We've always done it that way.
Re: Pivot post
We use an electric die grinder as well, stuff lots of wet rags around the area to keep the sparks in check, fire extinguishers nearby too.
You can use a 3/4" 6 point deep socket with a slot ground across it to help install the studs.
Put a bolt through the hole in the stud, put the socket over the stud so the slot goes over the bolt, hold the nut and rachet the stud in place.
Beats doing the 1/2 turn thing with a punch.
I have a photo if anyone cares to host it.
We also use 3 flat washers instead of one, on some machines the nut will run out of thread before it is really tight, a few months later and the stud can start moving and egg out the frame.Please.....follow the instructions!!
John
804-240-4982
Re: Pivot post
i address my pivot problems the long and tedious way
once a month i take a lane out and totally strip the backend assy
rebuild the pit, repair any faulty nuts that are welded on the machine frame and last of all grind the original pivots off the machine frame and install the new pivots
currently where i am at, the techs previous haven't ground the old weld off they have just bolted the new pivots on, this causing the pivots not to sit flush and lockup the front roller hinges
it might take a bit of time, but i feel the pride in the job, and the performance of the outcome make it the right way to go
i have also seen centres physically bend the pivots until they snap off, now their machine frames are warped and buckled terribly.
i just installed my first plantinum carpet and i believe its so important to get best results from day onei don't need mods, i am a bloody genius
Re: Pivot post
i also have a problem at the moment where i am, that the previous techs have stretched all the front roller springs from putting them on in the most dangerous and brutal way
but i'll get through them problems over the next few monthsi don't need mods, i am a bloody genius
