Changing a carpet
  • Changing a carpet
    I am putting in my first Platinum AMF carpet.
    I had a broken pit supt. bracket on the ball door side.....that is why I had to change it.
    I have the bounce board in the carpet.
    When I put the carpet bounce board in the machine......I get it to the 7/10 line and give the assy. a good shove.
    Anyone else use this method?
    Re: Changing a carpet
    I do and then I get to wrestle with it to get it out from under the mounting bracket. I saw in a stahls book a pit board hook. never tried it but it has to be easier. this was keeps the chiropractor in business.
    Good Luck
    curt
      Giving it a shove was the way I was taught. Fighting the board under the support bracket sucks royally too. Definitely get a good workout on the back and knees. Trick: use Stahl's ugly white belts, then you won't have to change pits too much (hopefully).
      Indexer2
        I dont understand what you mean.
        But it just so happens I have a lane that needs the carpet changed. Be a pal and (SHOW) me that method ! ! !
          <font size="2" face="Verdana, Helvetica, sans-serif">The bounce board is inside the carpet.
          I do this in front of the mask.
          I push the assy. across the pindeck.
          I get it to the end.
          Then I shove the whole assy. into the pit.......that way the whole assy. HOPEFULLY stays on top of the pit support brackets.
            lol
            King I know what you mean. Just wanted someone to change my carpet for me.
            I dont kick the bounce plate. I take out the kick-back. Plenty of room to stand &amp; lower the bounce plate on supt. bracket.
              I too give it a shove, but I also grab the back to keep bounce board above the brackets. Changing a carpet is the only time a miss the 70s! Damn respot cells in the back!
              Gene Simmons for president!!!
                The only way to pull a pit for me is to get on top of the bounce plate. Now I'm 6"2 and 210 so I'm not small. I pull the cushion out of the way and I can stand over the bounce plate and put it in and take it out the pin wheel. I don't like to go out the pindeck because it requires to much laying around and crawling around on the pindeck. Thats just to hard on the knees and back.
                  I hear you on the part of being hard on the back and knees.
                  What I do insted of giving it a big shoove is I get the BB and carpet to the 7/10 line. From there I stradle it and put one foot in the pit area and the other on the pindeck. from there it's just a matter of lifting the BB and carpet into the pit on to the support brackets. That's just the way I was taught.
                    <font size="2" face="Verdana, Helvetica, sans-serif">I also take mine out through the pinwheel. Thats the easiest way for me.
                      That's my method too King.
                      I knew if I hung around this site long enough... eventually I'd have to agree with Jerry on something. [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
                      I can die happy now... my work here is done. :p
                        I pull mine through the pinwheel. One other place I work at has VERY little room behind the machines so instead of twisting and turning when I'm there they come out the front. I much prefer going through the pinwheel if at all possible
                          Yeah it does'nt take much to get the cushion out of the way. That for me is the best.
                              Originally posted by Larry The Table Guy:
                              I knew if I listened to Jerry, I would be much better off.
                              <font size="2" face="Verdana, Helvetica, sans-serif">Fixed
                              Ball Returns Shorted Out?
                              Trip rocker arm
                              Lower ball cushion board
                              Backend motor plug
                              82/70 combi motors
