Sweep won't run
  • Sweep won't run
    I know this has been posted before, but, I got a machine that the sweep won't run on. I found a piece of metal in the wireway. Got it out and checked the caps and wiring. Everything looked good. Put it back together and nothing. since then,
    changed chassis-no good
    changed caps-no good
    changed motor and gearbox-no good
    plugged table plug into sweep, it runs
    changed a couple of pins in c-1-no good
    I'm getting voltage at the motor plug
    I'm scratching my head here, HELP!!
    "When you eliminate the impossibilities, whatever is left, no matter how illogical, must be the answer"
    Re: Sweep won't run
    Check the low voltage switch at the control panel. Put a jumper on it or see if it is open.
      Re: Sweep won't run
      changed sweep reverse relay-no good
      Which switch? The sweep run or cycle?
        Re: Sweep won't run
        Instructomat.
        Either the scoring, or the managers control may have the machine in shadow bowl.
        Disconnect the wires on terminal 5 & 6 in the A&MC that go everywhere except the A&MC plug.
        Short these. If the machine cycles, there is a problem outside the A&MC.
        Hook up the 2 wires to the desk (M.C. switches) and see if it cycles.
        If it is AMF scoring, the LIU lane 'A' board could be bad - try swapping the boards.
        In the machine (back end control box), the sweep reverse switch could be bad as well as the sweep control switch. You can jump the sweep control switch to see if it is bad.
          Re: Sweep won't run
          No the motor is humming and then it trips the klixon. Only with the sweep plug hooked up. If I plug the table plug into it it works. We have Qubica scoring and XOP conversion.
            Re: Sweep won't run
            Well If the motor is humming it could be a bad cent mech swtich, but when you plug the table motor plug in there it works. That tells us the sweep motor/gearbox is good. You siad you changed caps and pins in the c1 plug. Next place to look is the sweep motor plug. Take it apart and made sure you dont have any bad connections there.
            Wang
              Re: Sweep won't run
              Start Capacitor in the wireway. that is why it runs with the table plug. It is now using the table caps.
                Re: Sweep won't run
                Mike
                He said he changed the caps?
                Wang
                  Re: Sweep won't run
                  I agree with Wang - it looks like you've eliminated almost everything except the sweep motor cable.
                  One other thing may be the sweep reverse switch as Ted suggested. A quick check would be simply to try running the motor backwards using the sweep reverse switch, since often they fail on one side of the switch only, not both.
                  Cheers,
                  Andrew.
                    Re: Sweep won't run
                    Origonally posted by Beowulf:
                    __________________________________________________ ____________
                    He also said nothing in his origonal post of the motor humming.
                      Re: Sweep won't run
                      Wang
                      <font size="2" face="Verdana, Helvetica, sans-serif">Good call Wang, I'm with ya here. Have seen this too many times, take that plug apart and check all connections there
                        Re: Sweep won't run
                        Hmm, found a piece of metal in the wireway huh? The chances are that it has shorted something out. About the only thing left that nobody has suggested yet is the resistors that sit right near the caps under the wireway.
                        Have a good look at them and use a multimeter to compare them with the table motor resistors. Change them if something doesn't look right.
                        Ray
                        Ray Jordan
                        Cybernetic Solutions/tenpintec
                        Australia
                          Re: Sweep won't run
                          Good call Ray.
                          Also check that the two green resistors aren't touching each other. This can cause problems too.
                          If the problem isnt in the plug either then my guess its going to be outside the machine, as Ted suggested.
                            Re: Sweep won't run
                            did he visually check the caps
                            or did he metre them with a suitable multimetre
                            i still reckon its a cap
                            has he tried taking his table motor off and plugging it into the sweep???
                              Re: Sweep won't run
                              <font size="2" face="Verdana, Helvetica, sans-serif">GEE what are you smoking or drinking! [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
                              did you even bother reading beowulfs first post!
                              did you just get chased by a crocodile!
